  3. problem with flattern cell view in layout
  • Subscribers 129
  • Views 13730
whitefan
whitefan over 12 years ago
hello,
      In schematic driven layout, when I use "GEN FROM SOURCE" option it creates single layer layout of each and every components and then I tried to flattern it by going into Hierarachy in menu and it will show multiple layers to me that's fine but when I select a layout of particular component then corresponding component in schematic should highlighted but this is not happening , mean suppose I have 4 capacitors than I never know which layout is of which capacitor.
     I assume you're using the "Flatten" menu item under the Edit->Hierarchy menu. You shouldn't do that.
    Instead, increase the display depth (usually the shift-F bindkey, or on Options->Display (set the Display Stop Level to 32) or on the Options tool bar you can set the display depth.
    At least I'm guessing that's what your problem was...
  • whitefan
    Hello sir!!
     Thank you very much for the guidance , you were right about the steps I followed and thank you for the suggestion.
