  3. Monte carlo pre-run script
  • Subscribers 132
  • Views 15754
LinuxMachine
LinuxMachine over 12 years ago
Hi
 I got help on running a prerun script but still have one remain issue. I run multiple simulations on the one MC corner to check mismatch, trim it out, snd verify trim.  I want to specify 2 seperate instances as the DUT for Monte carlo.
I got this function form Cadence help but it will only allow one DUT.
How can I specify 2 instances in the DUT's?
LJNaxlPreRunSetMCdut("I0")
(defun LJNaxlPreRunSetMCdut (DUTinstName)
    ;Call this after ocnxlSetCalibration to define the DUT instance
    ;e.g. LJNaxlPreRunSetMCdut("I0")
    (let (mcObj analDpl)
        (when _axlIsMCRun()
            mcObj = amcGetDataStruct( asiGetCurrentSession() )
            analDpl = amcGetAnalDpl(mcObj)
            analDpl->dutsummary = DUTinstName
            asiUpdateMonteCarloAnalysisObj(asiGetCurrentSession() amcGetAnalDpl(mcObj))
            printf("Setting DUT = %s\n " DUTinstName)
Regards
    Please contact customer support for this (if you've not done so already).
