  3. Error with Assura QRC using IBM 0.13um SiGe
  • Subscribers 132
  • Views 15046
sriram123
sriram123 over 12 years ago
I am using cadence verion:ic613
and Assura4.1-613 and ext 9.14
I can run Assura DRC and LVS fine but when I run QRC I get the following error.
 Please help me solve this error.
Sriram
  Cadence Extraction QRC - Parasitic Extractor - Version 9.1.4-p003 Thu Sep
16 19:40:23 PDT 2010
                            Copyright 2010 Cadence Design Systems, Inc.
INFO (EXTQRCXOPT-249) : For Assura inputs, if the "output_setup -directory_name" option was not
specified, it is automatically set to the input directory.
INFO (LBRCXM-624): No temperature processing will occur for the layer QY, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer HY, because this layerhas no Tc1 and Tc2.
INFO (LBRCXU-108): Starting
 /cad/cds/assura4.1-613/tools/assura/bin/rcxToDfII /home/rhome/murals3/bicmos8hp/simulation/mim_cap/__qrc.rcx_cmd -t -f /home/rhome/murals3/bicmos8hp/simulation/mim_cap/extview.tmp -w /home/rhome/murals3/bicmos8hp/simulation/mim_cap -cdslib /home/rhome/murals3/bicmos8hp/cds.lib
@(#)$CDS: rcxToDfII version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:46 (sfrh259) $
sub-version 4.1, integ signature 2009-06-09-1330
run on rs-02.ecse.rpi.edu from /cad/cds/assura4.1-613/tools.lnx86/assura/bin/32bit/rcxToDfII on Thu Nov 14 14:02:59 2013
Loading IBM PDK bicmos8hp Procedures
IBM PDK bicmos8hp Device Status table loaded.
INFO (LBRCXU-114): Finished /cad/cds/assura4.1-613/tools/assura/bin/rcxToDfII
INFO (LBRCXM-642): Constructing the RCX run script
Forking:  /cad/cds/ext9.14/tools/extraction/bin/32bit//capgen -substrate_stamping_off -techdir /cad/cds/IBM_PDK/bicmos8hp/V1.4.1.3HP/Assura/QRC/411 -lvs /home/rhome/murals3/bicmos8hp/simulation/mim_cap.xcn -p2lvs /cad/cds/IBM_PDK/bicmos8hp/V1.4.1.3HP/Assura/QRC/411/qrcTechFile -sw3d -encrypt -cap_ground_layer substrate -auto_reorder_off -exclude_gate_res -cap_unit 1 -canonical_res_caps -p PC,allGate,RX -length_units meters -lexclude PC -add_via_effect M1,RX -dsub ns,nw,pwell,well,RF_BULK,substrate -blocking CPW1_AM,STI_GOX,AM -blocking CPW1_LY,STI_GOX,LY -blocking CPW1_M1,STI_GOX,M1 -blocking CPW1_M2,STI_GOX,M2 -blocking CPW1_M4,STI_GOX,M4 -blocking CPW1_MQ,STI_GOX,MQ -blocking CPW2_AM,STI_GOX,AM -blocking CPW2_LY,STI_GOX,LY -blocking CPW2_M1,STI_GOX,M1 -blocking CPW2_M2,STI_GOX,M2 -blocking CPW2_M3,STI_GOX,M3 -blocking CPW2_M4,STI_GOX,M4 -blocking CPW2_MQ,STI_GOX,MQ -blocking DI_VPNP,STI_GOX,RX -blocking Gate:0.23,STI_GOX,RX,PC -blocking IND_AM_DT,STI_GOX,AM,LY -blocking IND_AM_M1:3.48,STI_GOX,M1,AM,LY -blocking RF_BULK,STI_GOX,RX,PC,M1 -blocking SYMIND_AM_CT_DT,STI_GOX,AM,LY,MQ -blocking SYMIND_AM_CT_M1:3.48,STI_GOX,M1,AM,LY,MQ -blocking SYMIND_AM_DT,STI_GOX,AM,LY -blocking SYMIND_AM_M1:3.48,STI_GOX,M1,AM,LY -blocking TL1_AM_LY,STI_GOX,LY,AM -blocking TL1_AM_M1,STI_GOX,M1,M2,M3,M4,MQ,LY,AM -blocking TL1_AM_M2,STI_GOX,M2,M3,M4,MQ,LY,AM -blocking TL1_AM_M3,STI_GOX,M3,M4,MQ,LY,AM -blocking TL1_AM_M4,STI_GOX,M4,MQ,LY,AM -blocking TL1_AM_MQ,STI_GOX,MQ,LY,AM -blocking TL1_LY_M1,STI_GOX,M1,M2,M3,M4,MQ,LY -blocking TL1_LY_M2,STI_GOX,M2,M3,M4,MQ,LY -blocking TL1_LY_M3,STI_GOX,M3,M4,MQ,LY -blocking TL1_LY_M4,STI_GOX,M4,MQ,LY -blocking TL1_LY_MQ,STI_GOX,MQ,LY -blocking TL1_M2_M1,STI_GOX,M1,M2 -blocking TL1_M4_M1,STI_GOX,M1,M2,M3,M4 -blocking TL1_M4_M2,STI_GOX,M2,M3,M4 -blocking TL1_M4_M3,STI_GOX,M3,M4 -blocking TL1_MQ_M1,STI_GOX,M1,M2,M3,M4,MQ -blocking TL1_MQ_M2,STI_GOX,M2,M3,M4,MQ -blocking TL1_MQ_M3,STI_GOX,M3,M4,MQ -blocking TL1_MQ_M4,STI_GOX,M4,MQ -blocking TL2_AM_LY,STI_GOX,LY,AM -blocking TL2_AM_M1,STI_GOX,M1,M2,M3,M4,MQ,LY,AM -blocking TL2_AM_M2,STI_GOX,M2,M3,M4,MQ,LY,AM -blocking TL2_AM_M3,STI_GOX,M3,M4,MQ,LY,AM -blocking TL2_AM_M4,STI_GOX,M4,MQ,LY,AM -blocking TL2_AM_MQ,STI_GOX,MQ,LY,AM -blocking TL2_LY_M1,STI_GOX,M1,M2,M3,M4,MQ,LY -blocking TL2_LY_M2,STI_GOX,M2,M3,M4,MQ,LY -blocking TL2_LY_M3,STI_GOX,M3,M4,MQ,LY -blocking TL2_LY_M4,STI_GOX,M4,MQ,LY -blocking TL2_LY_MQ,STI_GOX,MQ,LY -blocking TL2_M2_M1,STI_GOX,M1,M2 -blocking TL2_M3_M1,STI_GOX,M1,M2,M3 -blocking TL2_M3_M2,STI_GOX,M2,M3 -blocking TL2_M4_M1,STI_GOX,M1,M2,M3,M4 -blocking TL2_M4_M2,STI_GOX,M2,M3,M4 -blocking TL2_M4_M3,STI_GOX,M3,M4 -blocking TL2_MQ_M1,STI_GOX,M1,M2,M3,M4,MQ -blocking TL2_MQ_M2,STI_GOX,M2,M3,M4,MQ -blocking TL2_MQ_M3,STI_GOX,M3,M4,MQ -blocking TL2_MQ_M4,STI_GOX,M4,MQ -blocking am_transmission,STI_GOX,AM -blocking bend90AM,AM,LY -blocking bend90AM,AM,LY,M1 -blocking bend90AM,AM,LY,M2 -blocking bend90AM,AM,LY,M3 -blocking bend90AM,AM,LY,M4 -blocking bend90AM,AM,LY,MQ -blocking bend90LY,LY,M1 -blocking bend90LY,LY,M2 -blocking bend90LY,LY,M3 -blocking bend90LY,LY,M4 -blocking bend90LY,LY,MQ -blocking bend90M2,M2,M1 -blocking bend90M3,M3,M1 -blocking bend90M3,M3,M2 -blocking bend90M4,M4,M1 -blocking bend90M4,M4,M2 -blocking bend90M4,M4,M3 -blocking bend90MQ,MQ,M1 -blocking bend90MQ,MQ,M2 -blocking bend90MQ,MQ,M3 -blocking bend90MQ,MQ,M4 -blocking bondPad_top:6.0,STI_GOX,RX,M1,AM -blocking IND_AC_WIRE,STI_GOX,RX,M1,AM -blocking diff_ha_var_dev,STI_GOX,RX -blocking diff_ncap,STI_GOX,RX,PC,M1 -blocking gap1AM,AM,M4 -blocking gap1AM,AM,MQ -blocking ha_var_dev,STI_GOX,RX -blocking lange1LY,LY,M3 -blocking mim1_bot:2.0,LY,QY,HY,AM -blocking mim2_bot,LY,QY,HY,AM -blocking ncap_dev,STI_GOX,RX,PC,M1 -blocking ncap_dgx,STI_GOX,RX,PC,M1 -blocking npn_dev_0P20:0.52,STI_GOX,RX,M1 -blocking npn_dev_0P20CBE:0.52,STI_GOX,RX,M1 -blocking npn_dev_0P20CBEt:0.52,STI_GOX,RX,M1 -blocking npn_dev_0P20_HB:0.52,STI_GOX,RX,M1 -blocking npn_dev_0P20_HBt:0.52,STI_GOX,RX,M1 -blocking npn_dev_0P20t:0.52,STI_GOX,RX,M1 -blocking open1AM,AM,M4 -blocking open1AM,AM,MQ -blocking pfRF_dev:1.89,STI_GOX,RX,PC,M1 -blocking pfRF_dev_HV:1.89,STI_GOX,RX,PC,M1 -blocking pfRF_mul:1.89,STI_GOX,RX,PC,M1 -blocking pfRF_mul_HV:1.89,STI_GOX,RX,PC,M1 -blocking res8pc_dev:0.25,STI_GOX,RX,PC -blocking res8pc_term:0.25,STI_GOX,RX,PC -blocking res8rr_dev:0.4,STI_GOX,RX,PC -blocking rns8pc_dev:2.46,STI_GOX,RX,PC -blocking rns8rr_dev:2.46,STI_GOX,RX,PC -blocking rnw8pc_dev:0.25,STI_GOX,RX,PC -blocking rnw8rr_dev:0.4,STI_GOX,RX,PC -blocking rpw8pc_dev:0.25,STI_GOX,RX,PC -blocking rstub1AM,AM,M4 -blocking rstub1AM,AM,MQ -blocking shrt1AM,AM,M4 -blocking shrt1AM,AM,MQ -blocking singleCPW3,STI_GOX,M3 -blocking singleEnd3,STI_GOX,M1,M3 -blocking singleEnd3,STI_GOX,M2,M3 -blocking step180AM,AM,M4 -blocking step180AM,AM,MQ -blocking taper1AM,AM,M4 -blocking taper1AM,AM,MQ -blocking tee3AM,AM,M4 -blocking tee3AM,AM,MQ -blocking vpnp_coll,M1,M2 -blocking vpnp_dev,STI_GOX,RX,M1 -blocking yjnct3AM,AM,M4 -blocking yjnct3AM,AM,MQ -res_blocking CPW1_AM,am -res_blocking CPW1_LY,ly -res_blocking CPW1_M1,m1_parasitic -res_blocking CPW1_M2,m2_parasitic -res_blocking CPW1_M4,m4 -res_blocking CPW1_MQ,mq -res_blocking CPW2_AM,am -res_blocking CPW2_LY,ly -res_blocking CPW2_M1,m1_parasitic -res_blocking CPW2_M2,m2_parasitic -res_blocking CPW2_M3,m3 -res_blocking CPW2_M4,m4 -res_blocking CPW2_MQ,mq -res_blocking DI_VPNP:0.12,m1_parasitic -res_blocking IND_AM_DT,am,ly -res_blocking IND_AM_M1:3.48,m1_parasitic,am,ly -res_blocking SYMIND_AM_CT_DT,am,ly,mq -res_blocking SYMIND_AM_CT_M1:3.48,m1_parasitic,am,ly,mq -res_blocking SYMIND_AM_DT,am,ly -res_blocking SYMIND_AM_M1:3.48,m1_parasitic,am,ly -res_blocking TL1_AM_LY,ly,am -res_blocking TL1_AM_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,am -res_blocking TL1_AM_M2,m2_parasitic,m3,m4,mq,ly,am -res_blocking TL1_AM_M3,m3,m4,mq,ly,am -res_blocking TL1_AM_M4,m4,mq,ly,am -res_blocking TL1_AM_MQ,mq,ly,am -res_blocking TL1_LY_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly -res_blocking TL1_LY_M2,m2_parasitic,m3,m4,mq,ly -res_blocking TL1_LY_M3,m3,m4,mq,ly -res_blocking TL1_LY_M4,m4,mq,ly -res_blocking TL1_LY_MQ,mq,ly -res_blocking TL1_M2_M1,m1_parasitic,m2_parasitic -res_blocking TL1_M4_M1,m1_parasitic,m2_parasitic,m3,m4 -res_blocking TL1_M4_M2,m2_parasitic,m3,m4 -res_blocking TL1_M4_M3,m3,m4 -res_blocking TL1_MQ_M1,m1_parasitic,m2_parasitic,m3,m4,mq -res_blocking TL1_MQ_M2,m2_parasitic,m3,m4,mq -res_blocking TL1_MQ_M3,m3,m4,mq -res_blocking TL1_MQ_M4,m4,mq -res_blocking TL2_AM_LY,ly,am -res_blocking TL2_AM_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly,am -res_blocking TL2_AM_M2,m2_parasitic,m3,m4,mq,ly,am -res_blocking TL2_AM_M3,m3,m4,mq,ly,am -res_blocking TL2_AM_M4,m4,mq,ly,am -res_blocking TL2_AM_MQ,mq,ly,am -res_blocking TL2_LY_M1,m1_parasitic,m2_parasitic,m3,m4,mq,ly -res_blocking TL2_LY_M2,m2_parasitic,m3,m4,mq,ly -res_blocking TL2_LY_M3,m3,m4,mq,ly -res_blocking TL2_LY_M4,m4,mq,ly -res_blocking TL2_LY_MQ,mq,ly -res_blocking TL2_M2_M1,m1_parasitic,m2_parasitic -res_blocking TL2_M3_M1,m1_parasitic,m2_parasitic,m3 -res_blocking TL2_M3_M2,m2_parasitic,m3 -res_blocking TL2_M4_M1,m1_parasitic,m2_parasitic,m3,m4 -res_blocking TL2_M4_M2,m2_parasitic,m3,m4 -res_blocking TL2_M4_M3,m3,m4 -res_blocking TL2_MQ_M1,m1_parasitic,m2_parasitic,m3,m4,mq -res_blocking TL2_MQ_M2,m2_parasitic,m3,m4,mq -res_blocking TL2_MQ_M3,m3,m4,mq -res_blocking TL2_MQ_M4,m4,mq -res_blocking am_transmission,am -res_blocking bend90AM,am,ly -res_blocking bend90LY,ly,mq -res_blocking bend90M2,m2_parasitic,m1_parasitic -res_blocking bend90M3,m3,m2_parasitic -res_blocking bend90M4,m4,m3 -res_blocking bend90MQ,mq,m4 -res_blocking bondPad:6.0,m1_parasitic,am -res_blocking IND_AC_WIRE,m1_parasitic -res_blocking diff_ha_var_dev:2.48,m1_parasitic -res_blocking gap1AM,am -res_blocking ha_var_dev:1.3,m1_parasitic -res_blocking kq_term,ly -res_blocking lange1LY,ly,m3 -res_blocking mim1_bot:2.0,ly,am -res_blocking mim2_bot,ly,am -res_blocking open1AM,am -res_blocking res8n_term:0.02,m1_parasitic -res_blocking res8ns_term,m1_parasitic -res_blocking res8pc_term:0.07,pc_parasitic,m1_parasitic -res_blocking res8pc_term:0.25,pc_parasitic,m1_parasitic -res_blockiINFO (LBMISC-215205):
*** Cadence Extraction QRC Techgen -trans VERSION 9.1 Linux 32 bit - (Wed Sep 15 09:10:11 PDT 2010)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /home/rhome/murals3/bicmos8hp/simulation/mim_cap
WARNING (CAPGEN-41242): [input]: Via effect is already described in process file. -add_via_effect is obsolete and will be ignored.
WARNING (RCXSPIC-27116): There are no non-empty MOS/LDD devices with diffusion layer 'RX' and poly layer 'PC'. Cannot perform gate capacitance blocking for user-specified layer 'allGate'.
ng rstub1AM,am -res_blocking shrt1AM,am -res_blocking singleCPW3,m3 -res_blocking singleEnd3,m2_parasitic,m3 -res_blocking step180AM,am -res_blocking taper1AM,am -res_blocking tee3AM,am -res_blocking yjnct3AM,am /home/rhome/murals3/bicmos8hp/simulation/mim_cap
Successfully created RCX script '/home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx.sh'
INFO (LBRCXM-581): Checked out '1' license(s) for Virtuoso_QRC_Extraction_L 3.10
INFO (LBRCXM-608): Executing command
   /bin/ksh  /home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx.sh
##ADD_EXPLICIT_VIAS=N
##ADD_BULK_TERMINAL=N
##AGDS_FILE=/dev/null
##AGDS_LAYER_MAP_FILE=/dev/null
##HCCI_DEV_PROP_FILE=/dev/null
##AGDS_SPICE_FILE=/dev/null
##AGDS_TEXT_LAYERS=
##ARRAY_VIAS_SPACING=
##ASSURA_RUN_DIR=/home/rhome/murals3/bicmos8hp/simulation
##ASSURA_RUN_NAME=mim_cap
##BLACK_BOX_CELLS=/dev/null
##BREAK_WIDTH=
##CAP_COUPLING_FACTOR=1.0
##CAP_EXTRACT_MODE=decoupled
##CAP_GROUND=gnd
##CAP_MODELS=no
##DANGLINGR=N
##DEVICE_FINGER_DELIMITER='@'
##DF2=Y
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##ENABLESENSITIVITYEXTRACTION=N
##EXCLUDE_FLOAT_LIMIT=
##EXCLUDE_FLOAT_DECOPULING_FACTOR=
##EXCLUDE_FLOATING_NETS=N
##EXCLUDE_NETS_REDUCERC=/dev/null
##EXCLUDE_SELF_CAPS=N
##IGNORE_GATE_DIFFUSION_FRINGING_CAP=Y
##EXTRACT=both
##EXTRACT_MOS_DIFFUSION_AP=N
##EXTRACT_MOS_DIFFUSION_HIGH=
##EXTRACT_MOS_DIFFUSION_RES=N
##FILTER_SIZE=2.0
##FIXED_NETS_FILE=/dev/null
##FMAX=
##FRACTURE_LENGTH_UNITS=MICRONS
##FREQUENCY_FILE=/dev/null
##GROUND_NETS=
##GROUND_NETS_FILE=/dev/null
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=
##HCCI_RUN_NAME=
##HEADER_FILE=/dev/null
##HIERARCHY_DELIMITER='/'
##HRCX_CELLS_FILE=/dev/null
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=assura
##M_FACTORR=
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_FRACTURE_LENGTH=infinite
##MAX_SIGNALS=
##MERGE_PARALLEL_R=N
##MINC=
##MINC_BY_PERCENTAGE=
##MINR=0.001
##NET_NAME_SPACE=layout
##NETS_FILE=/dev/null
##OUTPUT=/home/rhome/murals3/bicmos8hp/simulation/mim_cap/extview.tmp
##OUTPUT_NET_NAME_SPACE=layout
##PARASITIC_BLOCKING_DEVICE_CELLS_TYPEgray
##PARASITIC_CAP_MODELS=no
##PARASITIC_RES_MODELS=no
##PARASITIC_RES_LENGTH=N
##PARASITIC_RES_WIDTH=N
##PARASITIC_RES_WIDTH_DRAWN=N
##PARASITIC_RES_UNIT=N
##PARTIAL_CAP_BLOCKING=N
##PEEC=N
##PIN_ORDER_FILE=/dev/null
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##POWER_NETS_FILE=/dev/null
##RC_FREQUENCY=
##RCXDIR=/home/rhome/murals3/bicmos8hp/simulation/mim_cap
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=/dev/null
##RCXFS_TYPE=none
##RCXFS_CUTOFF_DISTANCE=
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=no
##RISE_TIME=
##SAVE_FILL_SHAPES=N
##SINGLE_CAP_EDSPF=N
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##SPLIT_PINS_DISTANCE=
##SUB_NODE_CHAR='#'
##SUBSTRATE_PROFILE=/dev/null
##SUBSTRATE_STAMPING_OFF=Y
##TEMPDIR=/home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx_temp
##TEMPERATURE=25.0
##TYPE=full
##USER_REGION=/dev/null
##VARIANT_CELL_FILE=/dev/null
##VIA_EFFECT_OFF=Y
##VIRTUAL_FILL=
##XREF=/dev/null,/dev/null
##XY_COORDINATES=c,r
CASE_SENSITIVE=TRUE
export CASE_SENSITIVE
TEMPDIR=`setTempDir /home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx_temp`
setTempDir /home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx_tempexport TEMPDIR
cd /home/rhome/murals3/bicmos8hp/simulation/mim_cap
cat <<ENDCAT> caps2dversion
* caps2d version: 10
ENDCAT
cat <<ENDCAT> flattransUnit.info
meters
ENDCAT
QRC=Y
export QRC
cat <<ENDCAT> topcellxcn.info
ENDCAT
# Generate RCX input data from Assura LVS database
GOALIE2DIR=/cad/cds/ext9.14/tools/extraction/bin
export GOALIE2DIR
vdbToRcx /home/rhome/murals3/bicmos8hp/simulation mim_cap -unit meters -- -V1 \
-H satfile -r /home/rhome/murals3/bicmos8hp/simulation/mim_cap.xcn \
-df2 -xgl
@(#)$CDS: vdbToRcx version av4.1:Production:dfII6.1.3:IC6.1.3.500.10 06/09/2009 14:47 (sfrh259) $
6.2 Linux 32 bit - (Thu Feb 12 19:29:42 PST 2009)
Opening LVS data for mim_cap in /home/rhome/murals3/bicmos8hp/simulation
Open time is 0.0 sec.
Build pins/attributes took 0.2 sec.
Processing AM_pin_text                           1 shapes 0.0 sec.
Processing LY_pin_text                           1 shapes 0.0 sec.
Processing M1_pin_text                           1 shapes 0.0 sec.
create satfile took  0.05 user, 0.00 sys, 1.00 elapsed, 134704.0 kbytes
write edge AM_pin_text took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
write edge LY_pin_text took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
write edge M1_pin_text took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Building net map file. 0.0 sec.
create netmap file took 0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
create net file took 0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
WARNING (LBCLV-5652): No mosfet models provided. Can't create transfile
WARNING (LBCLV-5663): No bipolar models provided. Can't create bipolar files
WARNING (LBCLV-5660): No resistor models provided. Can't create resistor files
WARNING (LBCLV-5657): No diode models provided. Can't create diode files
Device creation took 0.0 sec
Processing mim1_bot_via                          1 shapes 0.0 sec.
write edge mim1_bot_via took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing mim1_top_via                          1 shapes 0.0 sec.
write edge mim1_top_via took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing ca6                                   2 shapes 0.0 sec.
write edge ca6 took  0.01 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
write edge sub_dev_Device_98 took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
write edge mim1dt_Device_69 took  0.00 user, 0.01 sys, 0.00 elapsed, 134852.0 kbytes
Processing sub_dev_Device_98                     1 shapes 0.0 sec.
Processing mim1dt_Device_69                      1 shapes 0.0 sec.
Processing subs_ndt                              1 shapes 0.0 sec.
write edge subs_ndt took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing m1_parasitic                          1 shapes 0.0 sec.
write edge m1_parasitic took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing m1                                    1 shapes 0.0 sec.
write edge m1 took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing ly                                    1 shapes 0.0 sec.
write edge ly took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing am                                    1 shapes 0.0 sec.
write edge am took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
write edge transmission took  0.00 user, 0.00 sys, 0.00 elapsed, 134852.0 kbytes
Processing transmission                          0 shapes 0.0 sec.
Processing mim1_bot                              1 shapes 0.0 sec.
write edge mim1_bot took  0.00 user, 0.00 sys, 0.00 elapsed, 135036.0 kbytes
Processing mim1_top                              1 shapes 0.0 sec.
write edge mim1_top took  0.00 user, 0.00 sys, 0.00 elapsed, 135168.0 kbytes
Processing substrate_text                        1 shapes 0.0 sec.
write edge substrate_text took  0.00 user, 0.00 sys, 0.00 elapsed, 135300.0 kbytes
Processing substrate                             1 shapes 0.0 sec.
write edge substrate took  0.00 user, 0.00 sys, 0.00 elapsed, 135432.0 kbytes
Processing sub_diff_top                          1 shapes 0.0 sec.
write edge sub_diff_top took  0.00 user, 0.00 sys, 0.00 elapsed, 135564.0 kbytes
write edge bperi took  0.00 user, 0.00 sys, 0.00 elapsed, 135696.0 kbytes
WARNING (LBCLV-5576): Ignoring duplicate layer-generation request of bperi (id 18)
write edge dpo took  0.00 user, 0.00 sys, 0.00 elapsed, 135696.0 kbytes
WARNING (LBCLV-5576): Ignoring duplicate layer-generation request of dpo (id 20)
Processing bperi                                 0 shapes 0.0 sec.
Processing dpo                                   0 shapes 0.0 sec.
sort edges took  0.01 user, 0.07 sys, 0.00 elapsed, 3964.0 kbytes
sort labels took  0.00 user, 0.01 sys, 0.00 elapsed, 3868.0 kbytes
sort edges and labels took  0.04 user, 0.10 sys, 0.00 elapsed, 135436.0 kbytes
vdbToRcx System Usage:
Elapsed:     1 seconds.
CPU:         0.3 seconds
Memory      66 Meg
GOALIE2DIR=/cad/cds/ext9.14/tools/extraction/bin/32bit/
export GOALIE2DIR
# Generate power list
cat global.net > power_list
# Prepare resistance  blocking layers
grow -V -m 2.0 mim1_bot g_1_mim1_bot
grow took 0.00 user, 0.00 sys, 0.00 elapsed, 5796.0 kbytes
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 5780.0 kbytes
geom ly g_1_mim1_bot - ly__c,11,i,1
geom ly g_1_mim1_bot - ly,10,i,1
geom am g_1_mim1_bot - am__c,11,i,1
geom am g_1_mim1_bot - am,10,i,1
# Create ports for abutment
geom -C am - am,1,i,1
geom -C am__c - am__c,1,i,1
inter am am__c -t am_am__c_butt:edge
geom -C ly - ly,1,i,1
geom -C ly__c - ly__c,1,i,1
inter ly ly__c -t ly_ly__c_butt:edge
/bin/mv -f substrate substrate_orig
epick substrate_orig substrate
/bin/mv -f substrate_text substrate_text_orig
epick substrate_text_orig substrate_text
/bin/mv -f subs_ndt subs_ndt_orig
epick subs_ndt_orig subs_ndt
# Ensure vias do not extend beyond routing
geom -V ca6 m1_parasitic sub_diff_top - ca6_m1_parasitic_sub_diff_top,111,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 5872.0 kbytes
geom -V mim1_bot_via mim1_bot ly - mim1_bot_via_mim1_bot_ly,111,i,2
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 5784.0 kbytes
geom -V mim1_top_via mim1_top am - mim1_top_via_mim1_top_am,111,i,2
geom -V substrate substrate_text - substrate_substrate_text_ovia,11,i,1
geom -V subs_ndt substrate - subs_ndt_substrate_ovia,11,i,1
geom -V mim1_bot_via mim1_bot ly__c - mim1_bot_via_mim1_bot_ly__c,111,i,2
geom -V mim1_top_via mim1_top am__c - mim1_top_via_mim1_top_am__c,111,i,2
geom -V am am_am__c_butt - am_am_am__c_butt_ovia,11,i,1
geom -V am__c am_am__c_butt - am__c_am_am__c_butt_ovia,11,i,1
geom -V ly ly_ly__c_butt - ly_ly_ly__c_butt_ovia,11,i,1
geom -V ly__c ly_ly__c_butt - ly__c_ly_ly__c_butt_ovia,11,i,1
/bin/mv -f substrate_orig substrate
/bin/mv -f substrate_text_orig substrate_text
/bin/mv -f subs_ndt_orig subs_ndt
# Flatten net file, routing, via and device layers
SAVEDIR=`beginFlattenInputs`
beginFlattenInputsexport SAVEDIR
/bin/mv -f NET h_NET
flatnet -V -li -h '/' h_NET NET
flatnet took 0.00 user, 0.00 sys, 0.00 elapsed, 5620.0 kbytes
netprint -V -N1 power_list:power_list_nums NET
flattenCapData mim1dt_Device_69 meters
flattub took  0.00 user, 0.00 sys, 0.00 elapsed, 5576.0 kbytes
flatnet took 0.00 user, 0.00 sys, 0.00 elapsed, 5616.0 kbytes
flattrans took 0.00 user, 0.00 sys, 0.00 elapsed, 5612.0 kbytes
flattenDeviceData BOX meters
flattrans took 0.00 user, 0.00 sys, 0.00 elapsed, 5600.0 kbytes
flattenLayers -m ca6 mim1_bot_via mim1_top_via am mim1_top ly m1_parasitic \
substrate ca6_m1_parasitic_sub_diff_top sub_diff_top \
mim1_bot_via_mim1_bot_ly mim1_bot mim1_top_via_mim1_top_am \
substrate_substrate_text_ovia substrate_text subs_ndt_substrate_ovia \
subs_ndt mim1_bot_via_mim1_bot_ly__c ly__c \
mim1_top_via_mim1_top_am__c am__c am_am_am__c_butt_ovia am_am__c_butt \
am__c_am_am__c_butt_ovia ly_ly_ly__c_butt_ovia ly_ly__c_butt \
ly__c_ly_ly__c_butt_ovia sub_dev_Device_98 m1
flattub took  0.05 user, 0.14 sys, 3.00 elapsed, 5580.0 kbytes
endFlattenInputs
# Initialize CAP_GROUND variable
CAP_GROUND=`findCapGround -g gnd -l substrate NET`
findCapGround -g gnd -l substrate NETecho "CAP_GROUND=" ${CAP_GROUND}
CAP_GROUND= 1
export CAP_GROUND
# Segregate interconnect into resistive and non-resistive
selectNetsByNumber power_list_nums am p_ram np_ram
epick took  0.00 user, 0.00 sys, 0.00 elapsed, 5504.0 kbytes
selectNetsByNumber power_list_nums am__c p_ram__c np_ram__c
selectNetsByNumber power_list_nums am_am__c_butt p_ram_am__c_butt np_ram_am__c_butt
selectNetsByNumber power_list_nums ly p_rly np_rly
selectNetsByNumber power_list_nums ly__c p_rly__c np_rly__c
selectNetsByNumber power_list_nums ly_ly__c_butt p_rly_ly__c_butt np_rly_ly__c_butt
selectNetsByNumber power_list_nums m1 p_rm1 np_rm1
selectNetsByNumber power_list_nums m1_parasitic p_rm1_parasitic np_rm1_parasitic
selectNetsByNumber power_list_nums mim1_bot p_rmim1_bot np_rmim1_bot
selectNetsByNumber power_list_nums mim1_top p_rmim1_top np_rmim1_top
selectNetsByNumber power_list_nums sub_diff_top p_rsub_diff_top np_rsub_diff_top
selectNetsByNumber power_list_nums subs_ndt p_rsubs_ndt np_rsubs_ndt
selectNetsByNumber power_list_nums substrate p_rsubstrate np_rsubstrate
selectNetsByNumber power_list_nums substrate_text p_rsubstrate_text np_rsubstrate_text
# Create resistive interconnect CAP terminals
createCapDiodeTerm mim1dt_Device_69 np_rly mim1dt_Device_69_ly_cvia
geom took  0.00 user, 0.00 sys, 0.00 elapsed, 5732.0 kbytes
# Prepare non-resistive text layers
flatlabel -V -tc -F LY_pin_text LY_pin_text_nr_labs
INFO (FLTLBL-89003): exec labsort -V LY_pin_text_nr_labs
sort labels took  0.00 user, 0.00 sys, 0.00 elapsed, 3740.0 kbytes
flatlabel took 0.00 user, 0.00 sys, 0.00 elapsed, 5444.0 kbytes
flatlabel -V -tc -F AM_pin_text AM_pin_text_nr_labs
INFO (FLTLBL-89003): exec labsort -V AM_pin_text_nr_labs
# Assign net numbers to cut regions
/bin/mv -f np_rsubstrate np_rsubstrate.conn_orig
createEmptyLayer np_rsubstrate
/bin/mv -f np_rsubs_ndt np_rsubs_ndt.conn_orig
createEmptyLayer np_rsubs_ndt
/bin/mv -f np_rsubstrate_text np_rsubstrate_text.conn_orig
createEmptyLayer np_rsubstrate_text
connect -V -relocate NET np_ram__c:np_ram__c.conn \
np_ram_am__c_butt:np_ram_am__c_butt.conn np_rly__c:np_rly__c.conn \
np_rly_ly__c_butt:np_rly_ly__c_butt.conn np_rm1:np_rm1.conn \
np_rmim1_bot:np_rmim1_bot.conn np_rsubstrate:np_rsubstrate.conn \
np_rsub_diff_top:np_rsub_diff_top.conn np_rsubs_ndt:np_rsubs_ndt.conn \
np_rsubstrate_text:np_rsubstrate_text.conn \
np_rmim1_top:np_rmim1_top.conn mim1dt_Device_69_ly_cvia - \
substrate_substrate_text_ovia,7,10 subs_ndt_substrate_ovia,9,7 \
mim1_bot_via_mim1_bot_ly__c,6,3 mim1_top_via_mim1_top_am__c,11,1 \
am__c_am_am__c_butt_ovia,1,2 ly__c_ly_ly__c_butt_ovia,3,4 - \
LY_pin_text_nr_labs,3 AM_pin_text_nr_labs,1
relocate took 0.00 user, 0.11 sys, 1.00 elapsed, 111500.0 kbytes
connect took  0.00 user, 0.00 sys, 0.00 elapsed, 111500.0 kbytes
# Assign net numbers to resistor vias
geom -V ca6_m1_parasitic_sub_diff_top np_rsub_diff_top.conn - tmp_rca6_m1_parasitic_sub_diff_top,11,i,2
mergevia -V -i -unitarea 0.0256,0.0512,0.0768,0.128,0.256 \
tmp_rca6_m1_parasitic_sub_diff_top rca6_m1_parasitic_sub_diff_top - \
np_rm1_parasitic np_rsub_diff_top
/home/rhome/murals3/bicmos8hp/simulation/mim_cap/rcx.sh: line 314: 7243: Abort
ERROR (LBRCXM-609): Bad return status from RCX run. 0x6
INFO (LBRCXM-709): *****  QRC terminated abnormally  *****
    That's a pretty old version, and it's crashing. My first suggestion would be to try running with a current version of QRC (the current release is EXT131), and if it still crashes, you will need to contact customer support.
    Kind Regards,
