  3. Warning in technology file (mfgGridResolution).
  • Subscribers 133
  • Views 16344
baumanets
baumanets over 12 years ago
\o **************************************************************************
\o *    "Compactor" Technology File Checker                       *
\o
\o
\o
\o
\o
\o
\o Database units per user units:
\o      DBUPerUU = 1000
\o
\o Manufacturing Grid Resolution:
\o      mfgGridResolution = 0.005 user units
\o      MGRInDBU = 4 database unit
\o
\o
\o Checking Rules/Layers/Wires/Devices...
\w      Distance is not a multiple of `mfgGridResolution'.
\o spacingRules (#6): `viaSpacing "CO" ...'
\o      Value should be integer or real.
\w *WARNING* spacingRules (#8): `minSpacing "VIA1" 0.15'
\o spacingRules (#9): `viaSpacing "VIA1" ...'
\w *WARNING* spacingRules (#11): `minSpacing "VIA2" 0.15'
\o spacingRules (#12): `viaSpacing "VIA2" ...'
\w *WARNING* spacingRules (#14): `minSpacing "VIA3" 0.15'
\o spacingRules (#15): `viaSpacing "VIA3" ...'
\w *WARNING* spacingRules (#17): `minSpacing "VIA4" 0.15'
\o spacingRules (#18): `viaSpacing "VIA4" ...'
\w *WARNING* spacingRules (#26): `minNotch "PO" 0.15'
\w *WARNING* spacingRules (#39): `minWidth "OD" 0.11'
\w *WARNING* spacingRules (#45): `minWidth "VIA1" 0.13'
\w *WARNING* spacingRules (#47): `minWidth "VIA2" 0.13'
\w *WARNING* spacingRules (#49): `minWidth "VIA3" 0.13'
\w *WARNING* spacingRules (#51): `minWidth "VIA4" 0.13'
\o spacingRules (#59): `viaSpacing "VIA5" ...'
\o spacingRules (#65): `viaSpacing "VIA6" ...'
example VIA
spacingRules(
( minSpacing "VIA1" 0.15 )
( viaSpacing "VIA1" (3 0.19 0.17) )
tableSpacingRules(
( "viaSpacing" "VIA1"
("adjacentVias" (3) nil "distance" (0.19) nil)
((3 ">=") (0.19 "<")) 0.17
 How change MGRInDBU to fix warnings minWidth minSpacing?
  • Marc Heise
    Marc Heise over 12 years ago
    what release are you using?   ( CIW - Help - About)
    This is probably a bug in the tech checker.
     Kind regards,
    Marc
  • baumanets
     IC5141USR6
    CIW->HELP->ABOUT: 5.10.41.500.6.148
     I reproduced the same problem in a quick test in IC5141 (latest hotfix). I agree with Marc that it looks like a bug in the (now obsolete) tech checker. This has been replaced completely in IC61X and since IC5141 is no longer being maintained (the last hotfix was 2 years ago), you'll just have to ignore the warnings and errors.
