  3. Quick layer replacement within a whole Layout
  • Subscribers 132
  • Views 14813
Kabal
Kabal over 12 years ago
For example I have some big layout. And there are many metals with one layer name, if I do not want to go ahead and select each layer, go to its properties and replace its layer to another, and I want specific type of layer within design changed to another type right away automatically, how can it be done?
  • ColinSutlieff
    ColinSutlieff over 12 years ago
    Hi Kabal,
    Probably the easiest way (without selecting the objects of interest and using the Property Editor Assistant) is to use the Find/Replace features.
    Go to Tools->Find/Replace
    Search for: any shape (for example)      Click Add Criteria
    Select a layer to search for.
    In the  Replace section : select target layer.
    Then click Replace All.
     Regards
    Colin
  • Kabal
    yes.thanks.
