  3. meassuring delay in viva
  • Subscribers 132
  • Views 17154
jerry124
jerry124 over 12 years ago
dear all,
I would like to measure delay on signal "gap" simulated on two temp -40 and 125 with "trigger" option like:
dly_fr=delay( v("gap") 0.75 1 "falling" v("gap") 0.75 2 "rising" 1 1 t "trigger")
I am getting results like:
time delay(v("gap" delay(v("gap"
temp                       -40               125
17.8748u             38.4359u       7.67508u
56.3107u             9.60973u       38.4348u
65.9204u             38.4462u       9.60979u
104.367u             9.60927u        38.4452u
but I am expecting results something like:
17.8748u             38.4359u          38.XXXXu
56.3107u            38.XXXXu         38.4348u
65.9204u             38.4462u          38.XXXXu
(bold are expected values which also could be measured manually)
Signal shape is:
       ___       ___                            ___       ___
___|      |___|      |_____________|      |___|      |________
                           <       fr            >
and I would like to measure value fr.
How can I correctly measure value fr? What caracters 1 1 t in the command line (marked bold) mean?
THX
Jerry
    Jerry,
    Which subversion are you using? In recent versions that I've tried, ViVA uses the newer keyword argument form of delay() which is much clearer to see what the arguments mean because they are passed by name rather than order.
    The subversion can be found by doing Help->About... in the CIW.
    Kind Regards,
  • jerry124
     I am using version IC6.1.5-64b.500.10
    BR
    Jerry
    Jerry,
    If you build the expression in that version (using the calculator) you'd get the newer keyword argument version of the function - for example:
    delay(?wf1 v("gap" ?result "tran"), ?value1 0.75, ?edge1 "falling", ?nth1 1, ?td1 0.0, ?wf2 v("gap" ?result "tran"), ?value2 0.75, ?edge2 "rising", ?nth2 2,  ?td2 0.0 , ?stop nil, ?multiple nil)
    which is much clearer as every argument is named. I did a bit of digging, and the ordered arguments are in this order (we seem to have removed this from the documentation):
    wf1 value1 nth1 edge1 wf2 value2 nth2 edge2 period1 period2 multiple xName
    The default is that the second edge is relative to time, rather than the first edge.
    So I believe your expression is equivalent to:
    delay(?wf1 v("gap" ?result "tran"), ?value1 0.75, ?edge1 "falling", ?nth1 1, ?td1 0.0, ?wf2 v("gap" ?result "tran"), ?value2 0.75, ?edge2 "rising", ?nth2 2,  ?td2r0 0.0 , ?stop nil,  ?period1 1 ?period2 1 ?multiple t ?xName "trigger" )
    This means that:
    • The bold t in your expression indicates that you are generating multiple delays, from the first falling edge to the second rising edge on the waveform gap. The second edge is not relative to the first.
    • It is using periodicity of 1 for both (the two bold 1s).
    It's not clear to me if you really want the ?multiple occurrences or not.
    So my recommendation would be to try building the expression in the calculator and check to see what  you're getting, rather than using this positional argument version (I even checked back in IC5141 and the keyword argument version is documented there too).
