  3. Unified Reliability Interface for a macro model
  • Subscribers 132
  • Views 16167
JulianLeander
JulianLeander over 12 years ago
I try do design a shared library for the unified reliability interface. The model I design it for, is a macro model or uses a subckt:
//inline subckt modhb ( d g s b t psub )
// Parameters: w l nrd nrs ad as pd ps
parameters ...
+ isoVoltage=50
+ extract=extracted
+ rd_lin=0
+ delta_vth=0
rpoly2 ( d d1 ) bsource r=(rd_lin/exp(-0.1))*exp(-v(d,s))*(1-1/(1+100**(v(g,s)-1)))
modhb ( d1 g s b ) moshb w=w l=l nrd=1-07/w nrs=1-07/w ad=ad as=as pd=pd ps=ps m=ng
// Parasitic diodes
if (extract==0) {
xdsub ( psub t ) modnimdn_ps area=((l+1-06)*(w+2.4e-06)) perimeter=(2*(l+1-06+w+1e-06))
d1 ( b t ) tubtow area=((w+2.4e-6)*(l+4.1e-6)) perim=2*((w+2.4e-6)+(l+4.1e-6))
model tubtow diode level=1 \
     is=...    isw=...       n=...   \
    cjo=...      m=... \
    cjsw=...     mjsw=...     fc=...     vj=...  vjsw=...  \
      eg=...     xti=...      af=1
model moshb bsim3v3 version=...  type=n  capmod=... \
 mobmod=...  nqsmod=...  noimod=3 \
end modhb (The values are erased or changed)
In the shared libary I get the voltages and the currents for the calculations from the terminals of the MosVar structure.
I wanted to use the uri_mode=appendage, but I get this message:
Warning(RELXP-379): There is no subckt specified to replace in URI function getNewModelName(), appendage mode will be ignored.
Expanding subckt start...
Expanding subckt completed
Generating aged netlist start...
Generating aged netlist completed
Note: 2 deivces are not aged:
        M0.M_subinst_01.modnm
        M1.M_subinst_01.modnm
I used the standard getNewModelName() as written in the Unified Reliability Interface Reference:
int nmosnmGetNewModelName( URI_Model* model, const char* name, char* newname)
        sprintf(newname,"% aged",name)
        return 0;
My question is: How do I have to change this function or the model.scs file, that the appendage mode can be used and the devices are aged?
Best regards,
Julian
    Please contact customer support for this question.
  • JulianLeander
    well, I am a student and unfortunately it was not possible for my university to contact the customer support.
     Maybe somebody can still help.
     Julian
  • Tawna
    Tawna over 12 years ago
    Hi Julian,
     Each university that has Cadence software has a University liason to Cadence.   Please contact your Department Chairperson to find out whom that person is.  They should also have a website containing that information.
    The liason can contact Customer Support on your behalf and file a Case for you.
    best regards,
    Tawna
