  3. ADE-XL graphical outputs accessed from Skill
  • Subscribers 132
  • Views 15292
AxelS
AxelS over 12 years ago
I would like to access the graphical results display functions that are available in ADE-XL from a skill/ocean script.
For example, I would like to bring up the "spec summary" for a given history item.
Obviously I can create a non-graphical session
ses = axlCreateSession("session0")
sdb = axlSetMainSetupDBLCV(ses "lib" "cell" "adexl")
and access the history
hist = axlGetHistoryEntry(sdb "hist_item.0")
but the "view" function only works if I have started with a graphical session all along
axlViewHistoryResults(ses hist)
Is there any way to access this from an already running graphical virtuoso session?
Is there any way to access this completely scripted from a non-graphical session, similar to the "plot" function in ocean?
Many thanks!
Axel
    Axel,
    I've done quite a bit of digging, and I'm pretty certain this is not doable. The ADE XL UI has to be open to get the spec summary or view results pane. There's no public API to do this (and not really any private APIs that are in the right form).
    I did also look into ocnxlOutputSummary too, but that only seems to work if the  run was done in that OCEAN XL session.
    You can get at all the specs, and also all the scalar results (using axlReadHistoryResDB()), but you'd have to write all the formatting and spec output etc yourself.
    So probably you either need to open an ADE XL view (if this is running from "ocean" or "virtuoso -nographE", you could do that), or contact customer support to get an enhancement.
    Axel,
    Or maybe this:
     procedure(CCFopenADEXL(lib cell view historyName)
       let((win sess sdb hist)
         win=car(exists(wid hiGetWindowList()
           (sess=axlGetWindowSession(wid)) &&
           axlGetSessionLibName(sess)==lib &&
           axlGetSessionCellName(sess)==cell &&
           axlGetSessionViewName(sess)==view
         unless(win
           win=deOpen(list(nil 'libName lib 'cellName cell 'viewName view))
         sess=axlGetWindowSession(win)
         sdb=axlGetMainSetupDB(sess)
         hist=axlGetHistoryEntry(sdb historyName)
         axlViewHistoryResults(sess hist)
  • AxelS
    This works. Great, many thanks. What I was missing was the deOpen.
    Axel
