  3. Virtuoso 6.1.5 warnings issues
  • Replies 8
  • Subscribers 132
  • Views 20967
djamal
djamal over 12 years ago
I need some help if possible on the following issue:
*WARNING* (reader): string at line 1 was not terminated on EOF, '"' added at line 2 of string "...)"
I made a lot of search on google unfortunately without success.
Thank you in advance.
Note: The complete Log is given below.
Program:        @(#)$CDS: virtuoso version 6.1.5 09/07/2011 12:14 (sfsol608) $
Sub version:        sub-version  IC6.1.5.500.6  (32-bit addresses)
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading pvsskill.cxt.
Loading LVS.cxt
Loading layerProc.cxt
Loading xlUI.cxt
*WARNING* (reader): a '(' at line 1 was still unclosed on EOF, ')' added
                    at line 2 of string "...)""
*WARNING* (reader): illegal character '$' ignored at line 1 of string "...                        $"
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.11s.
Loading NCSU CDK 1.5.1 customizations...
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool adle
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool asimenv
*WARNING* envSetVal: Can't set the value of variable 'width',
    in tool[.partition] 'asimenv.plotting' - it has not been registered.
*WARNING* envSetVal: Can't set the value of variable 'height',
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool ddserv
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool layout
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool schematic
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool ui
loading vars from /home/dbenamrouche/uscn/ncsu-cdk-1.6.0.beta/cdssetup/cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool layoutOptimize
loading vars from ~/.cdsenv for tool asimenv
Loading NCSU SKILL routines...
Done loading NCSU_CDK customizations.
    If you run "virtuoso -nocdsinit" do the warnings go away?
  • djamal
    Using "virtuoso -nocdsinit" didn't resolve the problem. Below is the output generated in the CIW.
    COPYRIGHT © 1992-2011  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
              © 1992-2011  UNIX SYSTEMS Laboratories INC.,
                             Reproduced with permission.
    This Cadence Design Systems program and online documentation are
    proprietary/confidential information and may be disclosed/used only
    as authorized in a license agreement controlling such use and disclosure.
              RESTRICTED RIGHTS NOTICE (SHORT FORM)
    Use/reproduction/disclosure is subject to restriction
    set forth at FAR 1252.227-19 or its equivalent.
    Loading geView.cxt
    Loading schView.cxt
    Loading LVS.cxt
    Loading xlUI.cxt
    Loading auCore.cxt
    Loading vhdl.cxt
    Loading seismic.cxt
    Loading ci.cxt
    Loading ams.cxt
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.10s.
    Djamal,
    Can you check the contents of your ~/.cdsenv file (and possibly .cdsenv in working directory and <ICinstDir>/tools/dfII/local/.cdsenv if it exists) and post it here?
  • djamal
    First I want just to notify you on our time zone and weekend:
    Time Zone = GMT+1 (or UTC+1)
    Weekend = Friday + Saturday
    ________________________________________________________________________
    My .cdsenv under my home directory contains the following three lines:
    ~/.cdsenv
    layoutOptimize.state    menuState       string  "None"
    asimenv showWhatsNew string "5.1.0"
    asimenv.startup simulator string "spectre"
    The .cdsenv located in my working directory is given in an attached text file.
    While for the last one ( <ICinstDir>/tools/dfII/local/.cdsenv ), the <local> directory itself dose not exist. In the case it will help the listing of our ICinstDir is given below.
    [dbenamrouche@ruby Cadence]$ pwd
    /opt/Cadence
    [dbenamrouche@ruby Cadence]$ ll
    total 64
    drwxr-xr-x+ 27 cad      cad         1.0K Oct 28 11:44 ./
    drwxr-xr-x  19 root     sys          512 Jul  7 11:03 ../
    drwxrwxr-x+  4 cad      cad          512 Feb  7  2013 IScape04.11/
    -rw-r--r--   1 cad      cad         4.5K Jul 14 11:17 cadence_tools
    drwxrwxr-x+ 10 cad      cad          512 Feb 10  2013 cds_assura4.10CDB/
    drwxrwxr-x+ 11 cad      cad         1.0K Feb 11  2013 cds_assura4.1OA614/
    drwxrwxr-x+ 10 cad      cad          512 Feb 12  2013 cds_ccd10.1/
    drwxrwxr-x+ 10 cad      cad          512 Feb 13  2013 cds_confrml_10.1/
    drwxrwxr-x+ 12 cad      cad          512 Feb 13  2013 cds_edi10.1/
    drwxrwxr-x+ 12 cad      cad          512 Feb 13  2013 cds_et10.1/
    drwxrwxr-x+ 12 cad      cad          512 Feb 13  2013 cds_ets10.1/
    drwxrwxr-x+ 11 cad      cad          512 Jul 21 15:14 cds_ext10.1/
    drwxrwxr-x+ 11 cad      cad          512 Feb 12  2013 cds_ext9.1/
    drwxrwxr-x+ 12 cad      cad          512 Mar  4  2013 cds_ic5.1.41/
    drwxrwxr-x+ 13 cad      cad          512 Jul 17 15:57 cds_ic6.1.5/
    drwxrwxr-x+ 13 cad      cad          512 Mar  4  2013 cds_ic6.14/
    drwxrwxr-x+  9 cad      cad          512 Feb 12  2013 cds_icc_11.2.41/
    drwxrwxr-x+ 18 cad      cad         1.0K Aug  5  2011 cds_incisiv10/
    drwxrwxr-x+ 11 cad      cad          512 Feb 13  2013 cds_kqv5.1/
    drwxrwxr-x+ 11 cad      cad          512 Feb 14  2013 cds_lcu/
    drwxrwxr-x+ 11 cad      cad          512 Feb  3  2013 cds_lcu04.00/
    drwxrwxr-x+ 12 cad      cad          512 Jul 18 14:47 cds_mmsim10.1/
    drwxrwxr-x+ 11 cad      cad          512 Feb 12  2013 cds_mmsim7.2/
    drwxrwxr-x+ 11 cad      cad          512 Feb 13  2013 cds_pvs10.1/
    drwxrwxr-x+ 11 cad      cad          512 Feb 13  2013 cds_rc10.1/
    drwxrwxr-x+ 11 cad      cad          512 Jul 22 12:11 cds_rc11.1/
    drwxrwxr-x+ 17 cad      cad          512 Feb 13  2013 cds_vipcat11.3/
    drwxrwxr-x+  2 cad      cad          512 Mar  4  2013 netscape_bin/
    [dbenamrouche@ruby Cadence]$ ll cds_ic6.1.5/tools/dfII/
    total 24
    drwxr-xr-x+  9 cad      cad          512 Sep  7  2010 ./
    drwxr-xr-x+ 40 cad      cad         1.0K Jan 30  2009 ../
    drwxr-xr-x+  4 cad      cad         4.0K Jul 17 10:57 bin/
    drwxr-xr-x+  2 cad      cad          512 Jul 17 10:47 cdsuser/
    drwxr-xr-x+ 23 cad      cad          512 Jul 17 11:21 etc/
    drwxr-xr-x+  2 cad      cad          512 Jul 17 10:55 include/
    drwxr-xr-x+  2 cad      cad          512 Jul 17 10:55 lib/
    drwxr-xr-x+ 22 cad      cad          512 Jul 17 10:56 samples/
    drwxr-xr-x+  4 cad      cad          512 Jul 17 10:55 src/
    • dot-cdsenv.txt
    Djamal,
    This is cased by lines 55-60 of the .cdsenv in your working directory that you uploaded. I don't believe continuation characters are supported in .cdsenv (the backslash on each line). If you combine the entire entry onto a single line:
     spectre.envOpts    modelFiles       string  "$CDK_DIR/models/spectre/standalone/tsmc25N.m  $CDK_DIR/models/spectre/standalone/tsmc25P.m  $CDK_DIR/models/spectre/standalone/tsmc35N.m  $CDK_DIR/models/spectre/standalone/tsmc35P.m  $CDK_DIR/models/spectre/standalone/ami06N.m $CDK_DIR/models/spectre/standalone/ami06P.m"
    Then the warnings go away.
    Kind Regards,
  • djamal
     Andrew,
    It's fantastic the warnings have been disappeared. Thank you so much for your help and especially for the time you spent on the debugging process.
    In what follow I wonder and would like just to have your opinion. The output generated in the CIW still show two warnings which are directly related to the ncsu-cdk-1.6.0.beta. On the web some peoples say that we can ignore those warnings (unfortunately I didn't save the web link).
    Loading geView.cxt
    Loading schView.cxt
    Loading LVS.cxt
    Loading xlUI.cxt
    Loading auCore.cxt
    Loading vhdl.cxt
    Loading seismic.cxt
    Loading ci.cxt
    Loading ams.cxt
    Hi Djamal,
    In IC5141 there were cdsenv settings:
    asimenv.plotting width          int     564
    asimenv.plotting height         int     428
    which governed the size of the old AWD waveform window (I think). These were removed in IC61. It appears that the NCSU kit is still trying to set them.
    The warnings are benign though - all it is telling you is that you are trying to set some cdsenv settings that have not been registered - and as a result, they will have no effect.
    So you can safely ignore them. Or you can edit the cdsenv file it mentions and remove those two entries if you want to make the output a bit cleaner - but it won't make any difference at all to the behaviour.
    Kind Regards,
  • djamal
    Really thank you for all these details.
    Have a nice day and whishing you a very nice holidays.
    Best Regards
    Djamal
