  3. DRC error in resistor layout
  • Subscribers 132
  • Views 16445
whitefan
whitefan over 12 years ago
        I attached the snapshot of my rnhr_rf resistor after DRC run, it highlites nwell of resistor by giving error as "welnotr_StampErrorFloat", I can't get the meaning of this, please help me if anyone is using this library and having clue of it (I am using UMC mmrf180 library). Thank you.
  • whitefan
    Hello friends!!
             I solved the issue. As I mentioned that it is from UMC mmrf180 library and in that the resistor rnhr_rf comes with resisting material as poly but still the base of this poly is n-well and we have to connect this n-well to either VDD or GND whatever comes according to your design otherwise it shows that n-well is floating. Thank you.
