  3. Layout GXL: Flight wires not displaying
  • Subscribers 131
  • Views 18070
wewa
wewa over 12 years ago
I've got a problem with Layout GXL. From my schematic I created a layout. In Layout GXL I inserted all parts with Connectivity - Generate - All From Schematic. My problem is, that the flight wires are not displayed. I tried the Option Connectivity - Nets - Show/Hide all incomplete nets or I checed Options - Display - Nets but also this does not dispay any nets.
Can you help me?
Wy are no flight wires or nets displayed?
Best regards
wewa
    Which vesion are you using? I don't see a "Connectivity - Insert - All From Schematic" menu (I don't recall that in previous versions either). Maybe it is some customization or third-party tool which is not transferring the nets in the database?
    What do you get if you type in the CIW:
    geGetEditCellView()~>nets~>name
    geGetEditCellView()~>nets~>term~>name
    geGetEditCellView()~>nets~>instTerms
  • wewa
    I use the cadence version "IC615 C35B4". Virtuoso Layout Suite has version IC6.1.5-64b.500.132. And sorry it is not "Connectivity - Insert - All From Schematic" it is "Connectivity - Generate - All From Schematic" instead. And it worked for another cell, therefore I don't understand why flight wires are not displayed now.
    Here are the outputs of the commands:
    ("Vsp" "Vdd" "in" "Vsn" "GND")
    (nil nil nil nil nil)
     Best regards,
    wewa
    There doesn't appear to be any connectivity in your layout apart from the pins. Did you do Connectivity->Generate->All from Schematic again? Or Connectivity->Update->Components and Nets? Check for any error messages you might get in the CIW when you do these.
    I tried the version you're using and saw no problems.
    If this doesn't help, I suggest you contact customer support as we'll need to take a look at your data to find out what has gone wrong.
  • wewa
    and thank you for your help. I could solve my problem with Connectivity -> Define Device Correspondence. It seems that the link between layout and scematic was lost.
    Best regards
    wewa
