  3. ocean XL
  • Replies 14
  • Subscribers 132
  • Views 20031
ocean XL
analogdesign
analogdesign over 12 years ago
 Hai,
        I am very much new to oceanXL script.
        By using "save M1.m1:oppoint", i can't plot small signal parameters of MOS in ocean script.
        The expression willl appear as
        ocnxlOutputExpr( "getData("M1.m1:gm" ?result "dc-dc")" ?name "namegm" ?plot t ?save t).
        I would be thankful if anybody can post the solution for the above problem.
 krishna
  • analogdesign
    Hai sir,
              I again tried to run the script with your suggestions. Herewith i am attaching screen shots of result browser and error shown in icfb .
    satya krishna
  • analogdesign
    Hai sir,
             I am attaching the error that was shown in the ICFB window
    thanks
    satya krishna
     That's because you have a (pretty clear) syntax error in your script. You have:
     ocnxlOutputExpr("getData("M1.m1:gm" ?result 'dc)" ...)
    The problem is that you have quotation marks in the expression, and these are embedded within the string expression. So the string ends at the first quotation mark (so it just contains "getData(") and then some free text appears, and then you have " ?result 'dc)" - these are all stuck up against each other end hence you get syntax errors. It even tells you where they are!
    So you need to escape the embedded quotation marks:
     ocnxlOutputExpr("getData(\"M1.m1:gm\" ?result 'dc)" ...)
  • analogdesign
    Hai sir, Thanks for your reply. The script is working. thank you satya krishna
