  3. ocean XL
  • Replies 14
  • Subscribers 132
  • Views 20010
ocean XL
analogdesign
analogdesign over 12 years ago
 Hai,
        I am very much new to oceanXL script.
        By using "save M1.m1:oppoint", i can't plot small signal parameters of MOS in ocean script.
        The expression willl appear as
        ocnxlOutputExpr( "getData("M1.m1:gm" ?result "dc-dc")" ?name "namegm" ?plot t ?save t).
        I would be thankful if anybody can post the solution for the above problem.
 krishna
    Krishna,
    Can you see the signal in the results browser?  Maybe you could post the bottom part of the input.scs with the analysis statements.
    I assume you're doing a DC sweep?
    There's also a typo in what you have posted, because it has embedded quotation marks. It should be:
            ocnxlOutputExpr( "getData("M1.m1:gm" ?result \"dc-dc\")" ?name "namegm" ?plot t ?save t)
    or maybe better still:
            ocnxlOutputExpr( "getData("M1.m1:gm" ?result 'dc)" ?name "namegm" ?plot t ?save t)
  • analogdesign
     Hai sir,
               Thanks for your reply. I tried to run the script with your suggestions. But still it is not working. Its a dc sweep.
               From the result browser signals can be plotted. I am attaching the script here.
    ;======================input.scs file===========================================
    M1 (net3 net3 0 0) nsvtlp w=w1 l=0.1 nfing=1 mult=1 srcefirst=1 ngcon=1 \
            mismatch=1 lpe=0 dnoise_mdev=0 dmu_mdev=0 dvt_mdev=0 numcos=1 \
            numcod=1
    I2 (vdd! net3) isource dc=40u type=dc
    V0 (vdd! 0) vsource dc=1.2 type=dc
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        digits=5 cols=80 pivrel=1e-3 sensfile="../../../../psf/sens.output" \
        checklimitdest=psf
    dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
    dcOpInfo info what=oppoint where=rawfile
    dc dc param=w1 start=0.2 stop=3 step=0.1 oppoint=rawfile maxiters=150 \
    subckts info what=subckts  where=rawfile
    saveOptions options save=allpub subcktprobelvl=2
    ;====================== Tests setup ============================================
    ocnxlBeginTest("65nm_design:65_nmosexample:1")
    simulator( 'spectre )
    design( "65nm_design" "65_nmosexample" "schematic")
    analysis('dc ?saveOppoint t  ?param "w1"  ?start "0.2"
            ?stop "5"  ?step "0.1"  ?sort "name"  ?detail "node"
            ?threshold "0.0"  ?annotate "status"  ?maxsteps "10000"  ?maxiters "150"
            ?oppoint "rawfile"  ?write "spectre.dc"  ?sweep "Design Variable"  ?designVar "w1"
            ?rangeType "Start-Stop"  ?incrType "Linear"  ?stepTypeLin "Step Size"  ?stepTypeLog "Points Per Decade"  )
    desVar( "w1" 0.2    )
    saveOption( 'currents "all" )
    save( 'v "/net3" )
    temp( 27 )
    ocnxlOutputSignal( "/net3" ?plot t ?save t)
    ocnxlOutputExpr("getData("M1.m1:gm" ?result \"dc-dc\")" ?name "namegm" ?plot t ?save t)
    ocnxlEndTest() ; "65nm_design:65_nmosexample:1"
    krishna
  • analogdesign
     Hai sir,
    Thanks for your reply. I tried to run the script with your suggestions. But it didn't work. signals can be plotted from the result browser(previously suggested by you). Its a DC sweep. Here i am attaching the script.
    ;======================input.scsfile ===================================
            numcod=1
        checklimitdest=psf
    ;====================== Tests setup=====
    desVar( "w1" 0.2    )
    save( 'v "/net3" )
    temp( 27 )
  • analogdesign
     Hai sir,
              I am sorry if you get the same post multiple times.
              I tried to run the script with the modifications you suggested. But it didn't work. From the result browser its working( previously
    suggested by you) . Its DC sweep. Below i am attaching the script.
            numcod=1
        checklimitdest=psf
    desVar( "w1" 0.2    )
    save( 'v "/net3" )
    temp( 27 )
    thanks
    krishna
  • analogdesign
     Hai sir,
              I tried to run the script with the changes you suggested. It didn't work. From result browser its working. Its DC sweep.
    ;======================input.scsfile===========================================
            numcod=1
        checklimitdest=psf
    desVar( "w1" 0.2    )
    save( 'v "/net3" )
    temp( 27 )
    krishna
    Hi Krishna,
    I still would use ?result 'dc rather than ?result "dc-dc". I'm assuming that you do actually have an include file with the save statement somewhere?
    Can you show me a screenshot of the results browser showing where you can see the gm result?
    Probably best if you go to customer support - it's pretty hard to debug this without seeing the data.
    Kind Regards,
  • analogdesign
     Hi sir,
            Thanks for your reply. At present I was on leave, i will attach the screen shot, once i am back to work.
    krishna
  • analogdesign
    That was a blank post; you need to use the Options tab when posting to attach a picture.
  • analogdesign
