  3. Execution of ocean script in Cadence IC 6.1.5 and Cadence...
  • Subscribers 132
  • Views 16670
Execution of ocean script in Cadence IC 6.1.5 and Cadence IC 5.1.41
Lings
Lings over 12 years ago
I started to work recently on the new Cadence IC 6.1.5 moving from IC 5.1.4. I use Ocean Scripts and noticed that the ocean script takes a longer time to execute in the new version than in the old one. To verify this, I took a simple inverter circuit and performed the DC simulation analysis using Ocean script. I looped it 10 times for analysis purpose and measured the execution time. Executing the script in old version IC 5.1.41 produced a time of 130 sec while executing the same script in new version IC 6.1.5 produced a time of 502 sec.
Could anyone let me know the possible rootcause of this issue and possible solutions for it?
Lings
    Not without seeing your script. It's not something I've seen in general.
  • Lings
     Following is the ocean script I used for testing purpose:
    ocnWaveformTool( 'wavescan )
    simulator( 'spectre )
    design(     "~/Sim/Inverter_Simulation/spectre/schematic/netlist/netlist")
    resultsDir( "~/Sim/Inverter_Simulation/spectre/schematic" )
    modelFile(
        '("$AMS_DIR/spectre/c35/mcparams.scs" "")
        '("$AMS_DIR/spectre/c35/cmos53.scs" "cmostm")
        '("$AMS_DIR/spectre/c35/res.scs" "restm")
        '("$AMS_DIR/spectre/c35/cap.scs" "captm")
        '("$AMS_DIR/spectre/c35/bip.scs" "biptm")
        '("$AMS_DIR/spectre/c35/ind.scs" "indtm")
    analysis('dc ?dev "/V1"  ?param "dc"  ?start "0"
            ?stop "3.3"  ?step "0.1"  )
    desVar(      "wn" 1u    )
    desVar(      "l" 1u    )
    desVar(      "wp" 3u    )
    envOption(
        'paramRangeCheckFile  "$AMS_DIR/spectre/ams_range.lmts"
    temp( 27 )
    run()
    selectResult( 'dc )
    I used Python code to loop over this ocean script and measured the time.
    So is the python script running "ocean" each time? Or running virtuoso? What is it doing?
    Might it be the overhead of starting ocean each time that is the issue rather than the time to actally run the script? Perhaps you can add a:
    printf("START: %s\n" getCurrentTime())
    at the beginning and similar at the end (put END instead of START) - that way you can compare the time taken for the script itself. Also compare the simulation logs to see if the simulator itself is taking a different amount of time (not sure if it's the same version of spectre you're using).
  • Lings
     The python contains a shell script which runs the ocean script everytime.
    The time taken by the script is as follows:
    1. Executing ocean script in cadence-5 : 10 seconds
    2. Executing the same ocean script in cadence-6 : 95 seconds
    3. Executing the same ocean script in cadence-6  (fixing license checking order problem) : 75 seconds
    Lings
    There's still not really enough to go on here - you didn't say which license it was waiting for, and nor did you answer my earlier questions.
    Please contact customer support.
