  3. txt mode measurement result (*.mt* *.ms*)
  • Subscribers 133
  • Views 15470
archive over 19 years ago
hi! all:
        I have two questions about Spectre simulution
        If I run Spectre simulution in spice mode , how much precentage compability is it with Hspice?
        Is there any Specture command the same as ".measure  in Hspice"? ,then we can get the txt   mode measurement result (the same as *.mt* ,*.ms* in Hpsice.
Propolis
Originally posted in cdnusers.org by propolis
    SPICE compatibility should be reasonably complete. There are always corner cases where there can be issues, but there should not be many. The Spectre language alternative to .MEASURE is to use the MDL language to create measurements. This provides many more features than simple .MEASURES, but it is a different language.
    John
    Originally posted in cdnusers.org by john.odonovan
    You can learn mdl language from spectremdl. it is a pretty forward language to perform your task. You can get a tutorial from sourcelink.
    Originally posted in cdnusers.org by hcgooi
