  3. waveform processing question in Virtuoso ViVA
  • Subscribers 133
  • Views 17507
apple419
apple419 over 12 years ago
My system: Cadence IC615
 Sometimes when I do a DC sweep, I need to rearrange the X and Y axis.
 For example, in a voltage DC sweep, I got two signals shown on the viva. Var1 vs voltage, and Var2 vs voltage. In these two graphs, both have voltage as X axis. But if I want to see hwo Var2 varies with regarding Var1, meaning Var1 is my X axis and Var2 is my Y axi,. is it possible to do this in viva? I know I can export the raw data to Excel and draw from there. But if viva can do it then it will save some processing time.
Thanks!
  • Tawna
    Tawna over 12 years ago
    I very very quickly took a look at your question....  Is this what you are looking for?
    How to plot a design parameter versus an other in Wavescan/VIVA ?
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11562314
    -- or --
    Virtuoso Visualization and Analysis XL User Guide -- Using the Results Browser - Plotting Y vs Y for 2 signals
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/vivaxlug/vivaxlug6.1.5/chap2.html#1042930
    Best regards,
    Tawna
    Hi Tawna,
    Actually that solution isn't quite right for the Qt graph version of ViVA introduced in IC615; it's valid for IC614 and before (including IC5141). In IC615, you can plot the two waveforms, and then with the mouse over the x-axis, do Right Mouse-> Y vs Y.
    The second document shows how to use the Y vs Y button in the results browser as an alternative way of plotting it from the results browser.
  • apple419
    Tawna, Andrew,
      I got it. It works beautifully. Thanks for all your help!
    Regards
     Apple
  • Tawna
    Oops...you are absolutely right.  Thanks, Andrew!
    Best regards,
    Tawna
