  3. Pspice model errors in Virtuoso
  • Replies 9
  • Views 20432
Politekniko
Politekniko over 12 years ago
 Hi Guys
I am trying to simulate MAX9643U and EL7202 (using their Pspice models) as a part of my design, in Virtuoso. While I have reviewed many similar problems and solutions in this informative website, I still can not overcome the errors.
1) MAX9643U
(the model is available here:
www.maximintegrated.com/.../MAX9643U.LIB)
The problem points to the line:
Fi+ RS+ GND VALUE={-I(Vi+)+20.02u}
I read in one of the posts that I have replace {} by ''. but the error still exists and says:
"Expected 1 controlling voltage sources, but found 0"
2) EL7202
www.intersil.com/.../el7202.txt)
The problem (I guess) is related to the lines below:
.model spmod vswitch ron=3 roff=2meg von=1 voff=1.5
.model snmod vswitch ron=4 roff=2meg von=3 voff=2
e1 out vss table {(v(inp)-v(inm))*5000} = (0,0) (3.2,3.2)
and  the error says:
"Error (CMI-2078): I1016.sn: Required parameter 'file' is missing"
"Error (CMI-2078): I1016.sp: Required parameter 'file' is missing"
Any comment is highly appreciated, in advance
Politekniko
    I tried both those examples usign the new pspice_include statement that's in MMSIM13.1 and both parse with no issues.
    In IC616 (recent ISRs) there's now a pspice_include on the setup environment form in ADE, but if using an older version, create a file called (say) includePspice.scs containing pspice_include "MAX9643U.LIB" (for example). See "spectre -h pspice_include" for more details.
  • Politekniko
     Dear Andrew
     Hi and thanks a lot for your kind guidance.
     Could you please tell me how I can Analyze (or Calculate) the overall Efficiency of a circuit, including Op-Amps, FETs, Comparator, ... in Cadence Virtuoso? Is there such simulation in this design environement?
     Thanks a lot, in advance.
    It probably depends on what you mean by "Efficiency"...
  • Tawna
    Tawna over 12 years ago
    If you are talking about PSS analysis (periodic steady state analysis), there is a way to calculate PAE (power added efficiency).
    Article 1837740 Power Added Efficiency Calculation after PSS simulation
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=1837740
    There is an equation in this reference which shows the equation for efficiency, when defined as "The efficiency, η of the circuit is the proportion of all the energy dissipated in the circuit that is dissipated in the load."   You can create a calculator expression for this.
    As Andrew mentioned...there are different types of efficiency.  A clearer problem description will likely give you better answers.  :-)
    best regards,
    Tawna
  • Politekniko
    Dear Andrew and Tawna
    Thanks a lot for your both helps. I really appreciate it.
    Actually, my design is an Envelope Modulator for Envelope Tracking Power Amplifier. To find the overall efficiency of PA, we need to know the efficiency of the Envelope Modulator (Am I right?). Because of that, I am looking for a way to analyze / calculate this efficiency.
    Besides, in many relevant papers, I see they analyze the Efficiency of the Envelope Modulator. So, in this way, there should be a global definition for that.
    So, with my explained case, do you have any more guide?
    Thanks a lot, again
  • afuno
    afuno over 12 years ago
    Dear Andrew
     Thank you for the link. However, I haven't got the point...
    If I couldn't find "pspice_include" on the setup>environment in ADE, my version isn't IC616, right?
    Alternatively, I made the following way. But it doesn't work.
     1) Create a file called "pspice.scs" which constains the statement as the following. In the Model Libraries in ADE, this file has been included.
    pspice_include "mos.lib"
    2) Prepre a file "mos.lib"  which contains the model in PSPICE format.
    Unfortunately I wasn't able to find any information about "spectre -h pspice_include" for more details.
    Where am I supposed to find this information?
    You need to be using MMSIM13.1 to be able to use pspice_include. Check what "spectre -W" returns - unless it's a 13.1 version, "spectre -h pspice_include" won't work as it is not in the simulator.
  • afuno
     Dear Andrew
    Thank you, again. Unfortunately, I couldn't use MMSIM13.1 because it seems really new.
    "pspice_include" is also available in MMSIM12.11?
    I would like to ask you about this because you mentioned in the 1st message of this page, which is also shown as the following, that there is a way to use "pspice_include" in an older version.
    Current version in my instition is MMSIM10.11, where I couldn't use "pspice_include". But it can be upgrade up to MMSIM12.11. If I knew "pspice_include" was available in MMSIM 12.11, I will ask my colleague to upgrade to this version.
    Best regards,
    Yes, but in the same post that you reference, I also said "I tried both those examples usign the new pspice_include statement that's in MMSIM13.1".
    However, upon checking, this has also been backported to MMSIM12.1 ISRs from around the same time as MMSIM13.1. MMSIM131 was released in October 2013 (so I wouldn't call that "really new"), but it's also in MMSIM121 ISR13 onwards:
    UNIX> spectre -W
    sub-version  12.1.1.115.isr13
    That's not the MMSIM12.1.1 update release - but a hotfix based on the 12.1.1 update release. This build is dated 27th August 2013.
