  3. QRC: extract only down to a certain layout level
  • Subscribers 132
  • Views 16966
MarkusK
MarkusK over 12 years ago
Hi everybdoy,
is it possible to extract the parasitics of a layout only for some parts of the hierarchy?
E.g. I would like to extract the parasitics of the "top level" and the level below to see the parasitics of certain (very long) wires. Further I would like to use the extracted view to include these parasitics into a simulation. The "sub cells" sould be included as normal schematics in the simulation.
I tried with the HRX, but with my settings this generates the sub blocks as extracted views in an additional library...
 Thank you very much!
 Best regards,
Markus
    Markus,
    Look in the QRC documentation for black box (and maybe gray box) options. I've not thought too hard about what you're trying to do here - but that should give you some pointers for the kind of ways you could do this.
  • MarkusK
    Hello Andrew,
    thank you for the hint :-)
    Grey/black boxing is not doing the things I want, but based on this keywords I've found the correct option: "extraction_setup -ignore_cells_file xyz".
    Best regards,
    Markus
