  3. bsim3v3 model
  • Subscribers 133
  • Views 15306
bsim3v3 model
archive over 18 years ago
Hi All,
I'm looking for the signification of region numbers given by simulation of transistors in cadence when using the operating point analysis.
In other words, the simulation outputs a parameter named region. However this gives only a number. Could you give me the precise translation betweem numbers -> sat, off, subth, ...
Thks in advance
Axel
Originally posted in cdnusers.org by axp
    Enums in Spectre are numbered from 0, so for the bsim3v3 model, the region parameter has 5 possible values 0..4 (use spectre -h bsim3v3 to see the names), as follows off=0, triode=1, sat=2, ...
    John
    Originally posted in cdnusers.org by john.odonovan
