  3. VerilogA: report DC voltage
  • Subscribers 125
  • Views 14204
Frank Opteynde
Frank Opteynde over 11 years ago
I would like to make a component with a VerilogA model, doing the following:
The component has one voltage input pin (let's call it 'A').
During a DC sweep analysis, an output file is opened at the start of the analysis.  At each anlysis point, the DC voltage on node 'A' is reported in the file.  Then, after the DC sweep analysis is completed, the file is closed.
 How can I do this?
    `include "disciplines.vams"
    module reportDC(in);
    input in;
    electrical in;
    integer fp;
    analog begin
        @(initial_step)
            fp=$fopen("./%A_%M.txt");
        $fwrite(fp,"%g\n",V(in));
        @(final_step)
            $fclose(fp);
    end
    endmodule
