  3. pss simulation insufficient memory problem
  • Subscribers 133
  • Views 16208
archive over 18 years ago
I was trying to run a typical pss/qpss simulation of a mixer circuit. The simulation always crashes, saying insufficient memory. I checked the system resource, and was sure that system resource (including memory) was littlely used. Did anyone has similar situation and any tips to solve the problem? Otherwise I have to run transient simulation and do dft to check the result which is very painful. I am using icfb 5.10.41_USR3.27.
Thanks in adance.
Originally posted in cdnusers.org by willchen
    Without getting into the details of your RF simulation, try reducing your data points, using the swapfile option, using the new parser (+csfe), and finally, 64bit Spectre.
    I strongly suggest using a newer version of Spectre (the USR3 version you are using dates back 2005). There have since been memory handling improvements in Spectre. Try using IC5141USR5 or better MMSIM6.2.
    A thorough list of suggestions is available here:
    http://sourcelink.cadence.com/docs/db/kdb/2005/May/11178356.html
    Samir Jafferali
    Originally posted in cdnusers.org by AMSamirj
    So far, swap-file and save-selected, both in the output option and simulator option, help quite a bit. Though sometimes still get that crash issue.
