  3. how to create parameter passing symbol?
  • Subscribers 132
  • Views 23800
coiroibo
coiroibo over 12 years ago
Is there a procedure doc on how to create parameter passing symbol (for an inverter as an example)?
I'm trying to create a standard inverter which can be called with different transistors' sizes.
Thank you.
Coi
  • skillUser
    skillUser over 12 years ago
    Hi Coi,
    You are probably interested in using the pPar() parameter passing capability.  Here's an excerpt from the documentation:
    Passed Parameter Value of One Level Higher: pPar()
    When a parameter expression must depend on the value of a passed parameter, use the pPar function.
    pPar( "CDF_parameter_name" )
    The value of this expression is the value of the passed parameter.
    For example:
    pPar("vss")
    value of the "DC Voltage" parameter on the v27 instance in the aExamples opamp schematic is specified for the aExamples lowpass schematic as 15.
    When you create new symbols using automatic symbol generation (the Create Cellview - From Cellview command in the Schematic window), the system creates component parameters for the parameters you defined with pPar. The following illustration gives an example of the automatic symbol generation process.
    During netlisting, the pPar expression is substituted by the name of the parameter...
    I hope this helps,
    regards,
    Lawrence.
  • coiroibo
    Hi Lawrence,
    Can you post the link to the document?  Thank you for helping.
    Coi
  • skillUser
    Hi Coi,
    Here's the link to the IC616 documentation for this topic.
    Hopefully this will help.
    Lawrence.
  • coiroibo
    Hi Lawrence, Thank you. I figured out how to do it. Regards, Coi
