  3. Re: Help for SUB 1Volt BGR(band gap reference)cadence simulation...
  • Subscribers 131
  • Views 983
Re: Help for SUB 1Volt BGR(band gap reference)cadence simulation error
koundinya
koundinya over 12 years ago
Respected mam,
kindly help  by consedering this cadence Simulation error i'm getting
version Virtuoso 6.1.5
What possible changes i can make for resolving the erronious simulation
Please reply at my official Em id:  aceshivam99@gmail.com
{{ Analysis `tran' was terminated prematurely due to an error.
finalTimeOP: writing operating point information to rawfile.
Error found by spectre during DC analysis, during info `finalTimeOP'.
ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point.
Analysis `finalTimeOP' was terminated prematurely due to an error.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
subckts: writing subcircuits to rawfile. }]
Thanking you
Best Regards//
SHIVAM MISHRA
M.Tech -  VLSI DESIGN
4th Sem Student @ SRM UNIVERSITY
TamilNadu, India
    Well, you just broke several of the forum guidelines (please read them; the link will take you there, but they are the first post in each forum):
    1. You attached onto the end of an old thread
    2. Your append wasn't really related to the thread in question
    3. You appended into the RF Design forum yet this appears to be a transient simulation issue - so it's not clear why you picked that forum
    4. You have no information about the error (which was probably above that point in the log file)
    5. You didn't give which version of spectre you're using; the IC version isn't really relevant here.
    So not a lot to go on. I split your post off from the one you appended to, and moved it into the Custom IC Design forum. You're unlikely to get an answer without more information though.
    Kind Regards,
