  3. outputs(?type...) in IC12 ?
  • Subscribers 132
  • Views 1496
The Setlaz
The Setlaz over 12 years ago
 I'm trying to use the OCEAN outputs() function with the filter ?type in IC12.10.500 / 12.10.060 but I'm facing an error message.
I want to isolate the MOS devices from what returns the outputs() command.
Here is how I expect it to work and how it DOES work in IC6
ocean>openResults("./psf")
ocean> selectResults('dcOpInfo)
stdobj@0x2aa9d398
ocean> outputs()
("M0.Cs0" "M0.Cd0" "M0.Cds" "M0.Cg0" "M0.Cgs"    "M0.Cgd" "M0.Rg" "M0.Rs" "M0.Rd" "M0.XM"  "/V0" "/V1" "/V2" )
ocean> dataTypes()
("capacitor" "resistor" "tmibsimcmg" "vsource")
ocean> outputs(?type "tmibsimcmg")
("M0.XM")
EPIC SUCCESS !
Now, in IC12, everything is the very same, except the last command does not want to do the job:
*Error* car: argument #1 should be a list (type template = "l") - "tmibsimcmg"
ocean> outputs(?type "vsource")
*Error* car: argument #1 should be a list (type template = "l") - "vsource"
I kinda understand there could be an evolution allowing user to have a 'list of type' instead of a single type... Actually, that could be great... Let's try to make it 'list of type' compliant then:
ocean> outputs(?type '(tmibsimcmg))
*Error* _srrMakeSignalListFromType: argument #2 should be either a string or a symbol (type template = "gS") - (tmibsimcmg)
outputs(?type '("tmibsimcmg"))
*Error* _srrMakeSignalListFromType: argument #2 should be either a string or a symbol (type template = "gS") - ("tmibsimcmg")
ocean> outputs(?type '(vsource))
ocean> outputs(?type '("vsource"))
I just can't get it working...
Where is the trick ?
Unfortunately, the documentation seem not have been updated for this :'(
Damien
    Hi Damien,
    I reproduced the problem. It's broken in IC616 ISR3/4 and ICADV121 ISR5/6 (these correspond to each other).
    It's working in IC616 ISR5 (I checked a pre-release build) - that's due for release at the end of February.
  • The Setlaz
    Thanks a lot for this ! Looking forward to the next update then:)
    Meanwhile, here is the (ugly) workaround:
    rexMatchList( "[A-Za-z0-9_.<>]*.XM" outputs() )
    That should do the job for me at the moment.
    Damien
