  3. import hspice to virtuoso
  • Subscribers 133
  • Views 17382
Nav270
Nav270 over 12 years ago
Hi, Im importing a hspice netlist to virtuoso environment using
file>import>spice> HSPICE.
Im getting the schematics imported properly but they do not have symbol.
The  symbols are not generated.
Please let me know if Im missing something.
  • Quek
    Quek over 12 years ago
    Hi Nav270
    spiceIn will only generate the symbols if the cells are used in another cell within the same netlist. E.g.
    .subckt abc ...
    .ends
    spiceIn will not create a symbol for cell abc if it has not been instantiated in another subckt.
    .subckt abc ...
    .ends
    .subckt topCell ...
    XI1 ... abc
    .ends
    spiceIn will create a symbol for cell abc because it has been used in topCell.
    You can either create a dummy top level subckt which contains the instantiation of all the subcells or use a skillscript to generate symbols for the imported cells. The following 2 COS articles will be able to help you:
    11288840 :
    SKILL: Automatically Create or Generate Symbols for a Schematic Library
    11693840 :
    Perlscript to prepare a cdl netlist for import as Virtuoso 5141/614 schematic
    Best regards
    Quek
