  3. Power as input for behavioural source in a transient Spectre...
  • Subscribers 132
  • Views 15094
Power as input for behavioural source in a transient Spectre simulation
ChrisEAS
ChrisEAS over 12 years ago
Hi there.
During a transient simulation in Spectre, I would like convert the device power to a voltage signal. I tried using a behavioural source as follows:
E1 (1 0) bsource v="M1:pwr"
Unfortunately, this gets me the error message: Unexpected ternary operator ":"
Is there a way to achieve what I am trying to do?
Thanks, Chris
    You can't use operating point parameters or output parameters in the expressions (see "spectre -h bsource"). You could calculate the power by the current through the device multiplied by the voltage across it (source-drain) assuming that the current through the gate or bulk is small.
