  3. [Spectre] Multiple spectre instances compiling Ahdl behavioral...
  • Subscribers 133
  • Views 16776
[Spectre] Multiple spectre instances compiling Ahdl behavioral components
fgarcia
fgarcia over 12 years ago
 I am trying to  instantiate several instances of spectre with the aim of simulate INDEPENDENT circuits.
 However, the particularity of those circuits, (lets call them main), is that the netlists reference an external circuit which includes several behavioral sources ( we will call this circuit behavioral_circuit ).
 So, when I run in parallel the instances of spectre with the following concurrent commands, from the directory /path/,
    spectre -f psfascii +error +warn +log folder_0/0.log -r  folder_0/spectre_simulation folder_0/main_circuit_netlist.scs
    spectre -f psfascii +error +warn +log folder_1/1.log -r  folder_1/spectre_simulation folder_1/main_circuit_netlist.scs
    spectre -f psfascii +error +warn +log folder_n/n.log -r  folder_1/spectre_simulation folder_n/main_circuit_netlist.scs
spectre creates an ahdl compiling folder for each behavioral source in behavioral_circuit.
It seems that each the different instances of spectre try to compile the behavioral sources
    Reading link:  /opt/cadence/MMSIM121/tools.lnx86/spectre/etc/ahdl/discipline.h
    Reading file:  /opt/cadence/MMSIM121/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Reading link:  /opt/cadence/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file:  /opt/cadence/MMSIM121/tools.lnx86/spectre/etc/ahdl/constants.vams
which means that I have several spectre processes concurrently writing IN THE SAME folder:
    /path/main_circuit_netlist.ahdlSimDB
                 -->bsource.va.bsource_1.ahdlcmi
                 -->bsource.va.bsource_2.ahdlcmi
                 -->bsource.va.bsource_n.ahdlcmi
Therefore, I get errors due to this resource (folders) sharing.
With this scenario explained, I want to know if it is possible to compile the behavioral sources only one time (task done by the first spectre thread) and these resources be shared between the other instances.
If it is not possible, I would like to know how to tell spectre in which folder compile the sources.
( I know that I can run the following commands:)
    spectre -f psfascii +error +warn +log folder_0/0.log -r  folder_0/spectre_simulation folder_0/main_circuit_netlist_0.scs
    spectre -f psfascii +error +warn +log folder_1/1.log -r  folder_1/spectre_simulation folder_1/main_circuit_netlist_1.scs
    spectre -f psfascii +error +warn +log folder_n/n.log -r  folder_1/spectre_simulation folder_n/main_circuit_netlist_2.scs
Which produce the following output
     /path/main_circuit_netlist_0.ahdlSimDB
     /path/main_circuit_netlist_1.ahdlSimDB
     /path/main_circuit_netlist_2.ahdlSimDB
Fernando.
  • fgarcia
    I've found the solution: CDS_AHDLCMI_SHIPDB_COPY.
    However I am still trying to set CDS_AHDLCMI_SIMDB_DIR to place the compiled sources (it does not seem to work properly, cause all the compiled files are created in the path from where spectre is invoked).
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    You might want to try setting CDS_AHDLCMI_SHIPDB_DIR, see http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/veriaref/veriaref13.1/appF.html#1033232. However, I (and at least one other Cadence customer) have found that this method does not seem to be very reliable. CCR 1239276 has been filed for this.
  • fgarcia
     Thanks Frank.
    I am working on that, cause as you said it seems not to work always.
  • Frank Wiedmann
    If you keep having problems, please don't hesitate to contact Cadence Support and have them file another CCR on your behalf. This will improve our chances that Cadence will fix this soon. And if you manage to find a reliable solution, please let me know.
