  3. How to zoom to a particular location in layout editor(IC5141...
  • Replies 7
  • Subscribers 136
  • Views 8688
How to zoom to a particular location in layout editor(IC5141) by giving co-oridinates
RFStuff
RFStuff over 12 years ago
 Dear All,
I want to ZOOM IN to a particular location by giving (x,y) co-ordinate in virtuso layout editor.
Could any body please tell how it can be achieved,
Kind Regards,
  • Marc Heise
    Marc Heise over 12 years ago
    use the "Pan" command. The hotkey is usually the 'Tab" key. It will center your layout at the location you give by clicking with the mouse. Instead of the mouse click you can also just enter a coordinate in the ciw like:   16.5:10.3     and hit enter. It won't change the zoom ratio, so zoom first and Pan afterwards.
    Marc
    And in IC616 you can hit shift-N and type in the coordinates in a popup.
    In older versions, I used to use this kind of code (because it was more convenient than typing in the CIW):
    /* abPanPoint.il
    Author     A.D.Beckett
    Group      Structured Custom, Cadence Design Systems Ltd
    Machine    SUN
    By         A.D.Beckett
    Pan to typed in coordinate or move cursor to typed in coordinates.
    There are two public functions:
    abPanPoint()
    abCursorPoint()
    SCCS Info: @(#) abPanPoint.il 11/20/08.15:26:18 1.4
    *                    (abCreatePanPointForm)                    *
    *                Create the form for abPanPoint                *
    (procedure (abCreatePanPointForm)
      (let (coords zoomLevel)
           (setq coords
    	     (hiCreatePointField
    	      ?name 'coords
    	      ?prompt "Coordinates"))
           (setq zoomLevel
    	     (hiCreateRadioField
    	      ?name 'zoomLevel
    	      ?choices '("As is" "10" "100" "1000")
    	      ?prompt "Zoom Level"))
           (setq abPanPointForm
    	     (hiCreateAppForm
    	      ?name 'abPanPointForm
    	      ?formTitle "Pan to coordinate"
    	      ?callback 'abPanPointCB
    	      ?fields (list
    		       (list coords 0:0 320:35 105)
    		       (list zoomLevel 0:35 320:35 105))
    *                     (abPanPointCB form)                      *
    *                   Callback for abPanPoint                    *
    (procedure (abPanPointCB form)
      (let (win centre zoomLevel scaleFactor)
           (setq win (hiGetCurrentWindow))
           (setq centre (getq (getq form coords) value))
           /* scale the coordinates by the scaleFactor stored on the form */
           (when (setq scaleFactor (getq form scaleFactor))
    	     (setq centre (list
    			   (times (xCoord centre) scaleFactor)
    			   (times (yCoord centre) scaleFactor))))
           (if (equal (getq (getq form zoomLevel) value) "As is")
    	   /* pan to coordinates */
    	   (hiPan win centre)
    	   (progn
    	    /* otherwise zoom, using zoom level */
    	    (setq zoomLevel (quotient (atof (getq (getq form zoomLevel) value)) 2))
    	    (hiZoomIn win
    		      (list
    		       (list (difference (car centre) zoomLevel)
    			     (difference (cadr centre) zoomLevel))
    		       (list (plus (car centre) zoomLevel)
    			     (plus (cadr centre) zoomLevel))))
           t))
    *              (abPanPoint @optional scaleFactor)              *
    * Create and bring up the form, with an optional scale factor  *
    *               to multiply the coordinates by.                *
    (procedure (abPanPoint @optional scaleFactor)
      (unless (and (boundp 'abPanPointForm) abPanPointForm)
    	  (abCreatePanPointForm))
      (putpropq abPanPointForm scaleFactor scaleFactor)
      (hiDisplayForm abPanPointForm))
    *                  (abCreateCursorPointForm)                   *
    * Create the form for the user to specify the cursor position  *
    (procedure (abCreateCursorPointForm)
      (let (coords)
           (setq coords
    	     (hiCreatePointField
    	      ?name 'coords
           (setq abCursorPointForm
    	     (hiCreateAppForm
    	      ?name 'abCursorPointForm
    	      ?formTitle "Move cursor to coordinate"
    	      ?callback 'abCursorPointCB
    	      ?fields (list
    *                    (abCursorPointCB form)                    *
    *    Callback for the cursor point form. Actually moves the    *
    *                   cursor to that location.                   *
    (procedure (abCursorPointCB form)
      (let (win)
           (when form->coords->value
    	     (leZoomToPoint win form->coords->value)
           t
    *                       (abCursorPoint)                        *
    *    Create and bring up the form to move the cursor to the    *
    *                       specified point                        *
    (procedure (abCursorPoint)
      (unless (and (boundp 'abCursorPointForm) abCursorPointForm)
    	  (abCreateCursorPointForm))
      (hiDisplayForm abCursorPointForm))
  • RFStuff
     Dear Andrew,
    Thanks a lot.
    Could you please tell how to use this skill code.
    Basically what input to be  given in wgat sense.
    Kind Regards,
    Put the code in a file called abPanPoint.il and then in the CIW (or in your .cdsinit file) do:
     load("/path/to/abPanPoint.il")
    When you want to use it, type:
     abPanPoint()
    in the CIW. You can always assign this to a bindkey - for example:
     hiSetBindKey("Layout" "<Key>F8" "abPanPoint()")
    you'll get a popup form when you call this or hit the bindkey where you can type in the coordinate.
  • RFStuff
     Dear Andrew,
    thanks a lot !
    Is it possible to modify your code to make the zoom in option 1, 10, 100 ,1000 ?
    Kind Regards,
    Of course. Simply change the list of choices for the zoomLevel field in the function abCreatePanPointForm
  • RFStuff
