  3. LVS Problem running Fedora 19
  • Replies 14
  • Subscribers 133
  • Views 20214
ziikzak
ziikzak over 12 years ago
It seems that all the installation and configuration process using
Installscape are finished without problem, since my schematic simulation and DRC run very well, but I encounter an error message like the following when I try to work on LVS.
virtuoso:   ERROR: The command /tools/cadence/IC610/share/oa/bin/
sysname returned an error status:
                            unknown
virtuoso:    INFO: Note that OpenAccess (OA) requires running the
Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration
Guide" before
virtuoso:          you complete the configuration step. This manual is
included with
virtuoso:          the Cadence product documentation.
Thanks in advance you guys
  • Quek
    Quek over 12 years ago
    Hi ziikzak
    Would you please confirm the following?
    a. Are you able to start Virtuoso without any errors/warnings in CDS.log file?
    b. What is the version of Virtuoso? (virtuoso -W)
    c. Are you running Diva, Assura, Calibre or ... for DRC/LVS?
    d. Are there any warnings about OA installation when running DRC?
    It looks like a re-installation of IC61 package might be the easiest solution.
    Best regards
    Quek
    Also, do you have $OA_HOME set? Type "env | grep OA" in your terminal window. What does "ls -l <ICinstDir>/share/oa" show?
  • ziikzak
    Hi Querk,
    a. I did not see any error message in CDS.log
    b. my version is IC 6.1.5
    c. I run Assura for DRC/LVS
    d. No, running DRC is always easy
  • Quek
    Hi ziikzak
    Thanks for the info. As suggested by Andrew, would you also please check the following?
    terminal>env | grep OA_HOME
    Is OA_HOME variable set? If it is set, please unset it and retry LVS.
    Best regards
    Quek
  • ziikzak
     Yes, I did, and my terminal window did not show any thing.
  • Quek
    Hi ziikzak
    Would you please try the following?
    a. Open Assura LVS form
    b. Press the "View rsf" file button and save the file as "lvs.rsf"
    c. Execute LVS in a terminal window
    terminal>assura lvs.rsf
    Do you still see the same OA error?
    Best regards
    Quek
  • ziikzak
    I mean when i run env|OA_HOME, i did not see any respone.
     ziikzak
  • Quek
    Hi ziikzak
    Thanks for the clarification. It means that OA_HOME has not been set. Would you please try "assura lvs.rsf"?
    Best regards
    Quek
    Note that Fedora 19 is absolutely not a supported OS, and my guess is that you may be hitting an issue we saw where OA cannot identify the platform properly. First try using absolutely the latest IC and ASSURA versions (latest hotfixes of both, for the IC616 version) and if it still doesn't work you'll probably need to move to a supported OS (eg RHEL 6).
  • ziikzak
    yes, I tried.
    here is the error message popup
    Summary Report: inv.sum
     RSF           : inv.rsf
     Library Name  : Lib1
     Cell Name     : INVERTER
     View Name     : layout
     Rules File    : /home/huy/Documents/IBM_PDK/cmrf8sf/V1.8.0.0DM/Assura/LVS/extract41.rul
     Options       : -exec1 -LVS
     Work Directory: /home/huy/Documents/INDIVIDUAL/LVS/LVS
     Operating Mode: Legacy Mode is Off
    Starting dfIIToVdb...
    avlck:   ERROR: The command /apps/cadence/ASSURA615/share/oa/bin/sysname returned an error status:
                                unknown
    avlck:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
    avlck:          See the &quot;OpenAccess Installation and Configuration Guide&quot; before
    avlck:          you complete the configuration step. This manual is included with
    avlck:          the Cadence product documentation.
    Virtuoso Framework License (111) was checked out successfully. Total checkout time was 1.14s.
    @(#)$CDS: dfIIToVdb_64 version av4.1:Production:dfII6.1.5-64b:IC6.1.5-64b.500.17 08/06/2013 19:10 (sjfql419) $
    sub-version 4.1_USR4, integ signature 2013-08-06-1301
    run on localhost.localdomain from /apps/cadence/ASSURA615/tools.lnx86/assura/bin/64bit/dfIIToVdb on Mon Feb 17 00:00:27 2014
    *WARNING* CellView &quot;Lib1/INVERTER/layout&quot; does not exist in /apps/cadence/ASSURA615/share/cdssetup/cds.lib.
    *****  dfIIToVdb terminated abnormally  *****
    *WARNING* Translation abnormally terminated!
    *WARNING* aveng exit with bad status
    *WARNING* Status 256
    *WARNING* Assura execution terminated
    *****  aveng fork terminated abnormally  *****
