  3. Flushing output of a file in ocean script - drain comma...
  • Subscribers 132
  • Views 1732
Flushing output of a file in ocean script - drain command
samini
samini over 12 years ago
I want to know if there is a way to flush the output of file so it can be read immediately.
The only thing I could find was the drain command but this doesn't seem to do anything.
 The documentation on Ocean also doesn't actually list "drain" as a command which confuses me - drain is mentioned passively as part of the description for outfile...
    drain(port) is absolutely the right function. The OCEAN reference manual only documents a small subset of SKILL and so drain is covered in the main SKILL documentation.
