  3. A stochastic model in Verilog A for Monte Carlo simulat...
  • Replies 29
  • Views 41556
A stochastic model in Verilog A for Monte Carlo simulation
UUinfini
UUinfini over 12 years ago
 Hello Guys,
I have a problem for Veriglog A in Cadence, I hope you can help me. In fact I need to elaborate a stochastic model by coding in Verilog A executed under Cadence. My aim is to offer a model with which the customers can do the Monte Carlo Analysis. But I used the functions like "$random", "$temperature" etc. to generate a seed for obtaining a parameter which changes each time of simulation. But finally it changes just according to the real time of simulation, but not according to different times of simulation. Do you have any experiences like this? Thank you for you response.
Best regards,
UU
    You need to use the cds_inherited_parameter attribute on a parameter which you are going to have a mismatch definition of in the statistics block. For example, this VerilogA module:
    `include "disciplines.vams"
    module res(vp, vn);
    inout vp, vn;
    electrical vp, vn;
    (* cds_inherited_parameter *) parameter real monteres = 0;
    parameter real r = 1k;
    localparam real r_effective = r + monteres; // nominal resistance plus
    // monte-carlo mismatch effect
    analog
    V(vp, vn) <+ (r_effective)*I(vp, vn);
    endmodule
    And I'm simulating this from this netlist:
    parameters monteres=0
    statistics {
      mismatch {
        vary monteres dist=gauss std=5
    R1 (n1 0) res
    I1 (n1 0) isource dc=1m
    ahdl_include "monteres.va"
    monte montecarlo numruns=10 variations=mismatch {
       dc dc
       export vdc=oceanEval("v(\"n1\" ?result 'dc)")
  • UUinfini
     Thank you very much, I will try it.
  • UUinfini
     Hello Andrew,
    Thank you for your answer. How can we do the simulation with the second code? Is it written in a file".scs" ? And then how do we execute the simulation Monte Carlo? Thank you in advance for your answer.
    Best regards,
    UU
    You can run it with "spectre monteres.scs" for example, and the results will be in monteres.raw - including an mcdata file showing the variation of the points.
    Or you could create a veriloga view in virtuoso for the model, place an instance of it in a testbench similar to what I've done here, and then create a model file (called stats.scs, say) containing just the parameters and statistics block, and then include that as a model file in ADE - and then setup the monte carlo as you would usually in ADE.
    I just created a simple text-only example to show the principle without needing a database.
  • UUinfini
    Hello Andrew,
    Thank you for your guide. I have done as you said but it doesn't work, perhaps I have made some errors. I have created two files :
    1 source.va
    // VerilogA for source
    `include "constants.vams"
    module source(a,b,c);
    inout a;
         inout b,c;
         electrical a,b,c;
         integer seed;
         (*cds_inherited_parameter*)parameter real seedin = 0;
         analog begin
         seed=seedin;
         V(b) <+ cos(seed*100000000);
         V(c) <+ sin($abstime*300000000);
         $strobe("hello,I'm glad to meet you",seedin);
         end
    endmodule
    2 source.scs
    simulator lang=spectre
    ahdl_include "source.va"
    parameters seedin=0
    statistics {
      mismatch {
        vary seedin dist=gauss std=5
    .  Do you see any errors? Thank you.
    Best regards,
    UU
    Not sure what you mean by "it doesn't work". I created a simple circuit containing an instance of source, and then ran a monte carlo analysis:
    include "source.scs"
    I1 (a b c) source
    r1 (a 0) resistor r=1k
    r2 (b 0) resistor r=1k
    r3 (c 0) resistor r=1k
    monte montecarlo numruns=10 variations=mismatch savefamilyplots=yes {
       tran tran stop=10n
    This outputs a lot of stuff, but in particular it says (for each iteration of the monte carlo):
     hello,I'm glad to meet you -3.38873
    .hello,I'm glad to meet you -3.38873
    ..hello,I'm glad to meet you -3.38873
    ...hello,I'm glad to meet you -3.38873
    and then later:
         gmin = 1 pS
    hello,I'm glad to meet you 2.42183
    .hello,I'm glad to meet you 2.42183
    ..hello,I'm glad to meet you 2.42183
    (you're strobing on each timestep iteration, so because I ran a transient, it strobes multiple times).
    Because I ran with saving family plots, you can see your signal b in the monte carlo (see attached picture).
  • UUinfini
    First, I created a simple circuit
    Then a simulation Monte Carlo
    In the end the error came always like:
    Can you see what errors may I have?
    Thank you.
    UU,
    I see you sent me a direct email. As I am on vacation at the moment with limited access to my email, please post here (and make sure any pictures are uploaded via the options tab when posting). That way everyone can see the issue and possibly help out.
    I couldn't  see the error in your email anyway.
  • UUinfini
    Hello Andrew,
    When I created the file "source.scs" and "source.va" and did the Monte Carlo simulation with a simple circuit and importing "source.scs" as library, the following error came:
  • UUinfini
     Hello Andrew,
    I created the file "source.scs" and "source.va" and then executed the simulation Monte Carlo with "source.scs" imported as library using a simple circuit, and the attached error came.
    Best regards,
    UU
