  3. How to use the "derived layers" to check spacing between...
  • Subscribers 133
  • Views 1897
How to use the "derived layers" to check spacing between two layers in DRD ?
marbs
marbs over 12 years ago
 Hi All,
 How to use the "derived layers" to check spacing between two layers ?
 I have the technology file code below, but it is not working, if I run DRD .
 I use IC6.1.5 .
 Please help .
; LAYER DEFINITION
layerDefinitions(
 techDerivedLayers(
  ( insideLayer            10014       ( VIA12 'inside METAL1 ) )
 ) ;techDerivedLayers
) ;layerDefinitions
 CONSTRAINT GROUPS
constraintGroups(
  ( "foundry"    nil
    spacings(
     ( minSpacing                 "insideLayer"       12 )
    ) ;spacings
  ) ;foundry
) ;constraintGroups
Best Regards,
Marben F. Orallo
  • Quek
    Quek over 12 years ago
    Hi Marben
    DRD support for derived layers starts in IC616. Your codes should work in IC616. Would you please switch to IC616-500-4?
    Best regards
    Quek
  • Quek
    Hi Marben
    Please post non-SKILL related questions to "Custom IC Design" forum.
    Best regards
    Quek
  • marbs
     Hi Quek,
    Thanks for your reply and forum info .
    I will now post my problem in  "Custom IC Design" forum.
    Sorry for the inconvenience .
    Best regards,
    Marben
    Marben,
    I've moved the thread. No need to re-post it (and anyway, Quek has answered it).
