  3. Random DC voltage source generation
  • Views 19232
Tanvir100
Tanvir100 over 12 years ago
Hi there,
I am designing a 10 bit D/A converter and unfortunately my PDK does not support Monte Carlo Simulation.
At least to simulate the threshold voltage mismatch I am trying to create a voltage source or a set of voltage sources which will generate random voltage each time I run the transient simulation in Cadence Spectre ADE.
Then I can connect the bias node to the random dc source and then to the gate of the current source to observe the threshold voltage effect.
It is a bit urgent for me to come up with the idea to do this. It would be great if you could advice me how can I do this in Cadence?
Tanvir
  • Quek
    Quek over 12 years ago
    Hi Tanvir
    Perhaps you can try one of the following 2 methods:
    a. Use an ocean script to run the simulation. The script should contain a loop to vary the input voltages randomly.
    b. Manually add a statistical section in the model file and use ADE-XL to run monte carlo. This would be the easier method. E.g.
    statistics {
     mismatch {
      vary rn1_lvt dist=gauss std=1/1
    Best regards
    Quek
  • Tanvir100
    Dear Quek,
    Thanks for your suggestions. Unfortunately I am using IC 5.1 and I am not familiar witrh writing my own Ocean script. Feeling a bit odd.
    Would you please tell me is there anything in your mind ? May be with Verilog A?
    Any kind of advice is appreciated.
    Kind regards,
    Tanvir
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    Andrew Beckett has given you a more detailed answer at http://www.designers-guide.org/Forum/YaBB.pl?num=1392438653/1#1.
