  3. How to disable log message in terminal window
  • Subscribers 133
  • Views 16626
TFTandOLED1
TFTandOLED1 over 12 years ago
Hi
As you may know, the following command can be used to directly run OCEAN script in system terminal command window:
ocean oceanScript.ocn
While the script is running, a lot of messages prompt in the system terminal command window, which seem to slow down the running speed of the script. So, how to disable the log message so that they do not prompt in system terminal command window or get saved in any file? Thanks a lot!
  • Quek
    Quek over 12 years ago
    Hi TFTandOLED1
    Perhaps you are looking for this? : )
    /forums/T/13024.aspx
    Best regards
    Quek
  • TFTandOLED1
    Hello Quek
     This is exactly what I was looking for!
     Thank you so much!!
    Maofeng
