  3. Phase Delay in virtuoso
  • Subscribers 132
  • Views 18356
kenambo
kenambo over 12 years ago
Is there any option available to calculate phase shift directly in cadence virtuoso IC 6.1.5.
    Wouldn't you just do an ac analysis and then either divide one signal by the other (if it was intended to be a gain path) or subtract one from the other and then use the phase or phaseDeg calculator function on the result?
