  3. HOW TO CHANGE PIN PROPERTIES?
  • Subscribers 132
  • Views 17478
Heywire
Heywire over 12 years ago
I am changing the pin properties.I want to change lpp of the pin-rectangle which I have generated from schematic.
What I am doing npw is , after selecting the pin in layout
aaa=geGetSelSet()
and suppose it gives,  aaa~>lpp => (("MET1" "drawing"))
I want to change it to  (("MET1" "pin")).
Please post the procedure for it.
Anand
    Anand,
    No need to shout in your thread title!
    aaa~>lpp='("MET1" "pin")
    aaa is a list of dbObjects, and if you do listOfDbObjects~>attributeName=value it assigns value to the attribute name on every object - it's equivalent to:
    foreach(mapcar obj aaa obj~>lpp='("MET1" "pin"))
    (the mapcar is there because it returns a list of results)
  • Heywire
    Hello Andrew,
    After selecting the pin in layout, I did following in the CIW-
    aaa=geGetSelSet()
    aaa~>lpp    [it gives result- p, li { white-space: pre-wrap; }(("MET3SNL" "drawing"))]
    And,suppose I try to assign new value,  using,
    p, li { white-space: pre-wrap; } aaa~>lpp=(("MET3SNL" "pin"))  ....It gives following error p, li { white-space: pre-wrap; }
    *Error* eval: not a function - ("MET3SNL" "pin")
    What is the correct method to address this?
    Anand
  • skillUser
    skillUser over 12 years ago
    Hi Anand,
    This is because you have a list of objects for 'aaa' (as Andrew mentioned) - if you did
    "aaa=car(geGetSelSet())"
    then the code afterwards should work. Also if you followed Andrew's example of using the foreach(mapcar ...), it should have worked also.
    Lawrence.
  • skillUser
     Hi Anand,
    My mistake, I didn't read closely enough - it is because of the format you have put on the right hand side of the expression:
    (("MET3SNL" "pin"))
    This should be as Andrew suggested, something like:
    '("MET3SNL" "pin")
    Sorry for my mistake.
    regards,
    Lawrence.
  • Heywire
     Andrew and Lawrence,
    It works great. Thank you.
    Anand
