  3. Example Ocean measurement file in ADEXL
  • Subscribers 132
  • Views 17850
BradW
BradW over 12 years ago
I'm trying to create an ADEXL measurement using an Ocean script and I'm not having a lot of luck.  I've been trying to find a simple example but I've yet to see one in the manual or online.
Right now I'm just trying to get something very simple to work.  For example, I have a regular measure expression
if(((VAR("trace0") == 0) && (VAR("trace1") == 0)) 4 0)
which works just fine.  If I take this code and plug it into a file and then tell it to use this file as an Ocean script I get an "eval err".  Is there some special format I need to use within the ocean script to get it to work with ADEXL?
 I'm presently using IC6.1.5-64b.500.132
    The normal method would be for the first line of your OCEAN script to "advertize" the names of the outputs that it is going to produce using:
    axlAddOutputs('("myOut1" "myOut2"))
    Then you add the code to do all your computation, and when each output is ready, you can then do:
    axlOutputResult(if(((VAR("trace0") == 0) && (VAR("trace1") == 0)) 4 0) "myOut1")
    It is also possible to call axlOutputResult without a name and then that's the result of the script - useful if your script is only going to return one thing.
    Hopefully that helps!
  • BradW
    Thanks Andrew,
     That got me going but I have a couple follow on questions
    1.  Is there any way to use intermediate values calculated in other ADEXL measures inside the script?  It seems I have to redo all the calcs if I want their results available.
    2. When I include the script location in ADEXL it copies the script to another path and then updates the path.  Is there any way to make it keep the original reference?  Took me a while to figure out why my changes weren't being evaluated.
    3. More of a comment than question, but if you put a name in the Output in ADEXL where you are evaluating the script then that value can't be used for an actual variable name.  When would you ever want a name for the step that evaluates the script?  Seems like it shouldn't be possible.
  • aplumb
    aplumb over 12 years ago
    The approach I use to keep the code elsewhere, i.e. in a CVS/Git/SVN revision controlled hierarchy, is to use a SKILL load() operation to pull it into the Ocean script output wrapper file. Since pre-declaring axlAddOutputs() isn't necessary any more, it's possible to dynamically generate axlOutputResult() outputs algorithmically. The main limitation you'll run into however, is that any axlOutputResult() statements *not* found in the Ocean script wrapper won't show up in your Outputs Setup as dependent/grayed-out outputs. They'll only appear at simulation-evaluation time. Hope this helps! Andrew.
    To answer Brad's questions:
    1. You should be able to use calcVal("outputName") to reference an output computed previously outside the OCEAN script. I've not checked - but I believe this works (I think I've tried it before)
    2. You can control this with the following cdsenv:
      adexl.gui copyMeasurementScripts boolean nil
      or from SKILL: envSetVal("adexl.gui" "copyMeasurementScripts" 'boolean nil)
      The default is t, but with nil it leaves them at the original location
    3. If you use axlOutputResult(value) - i.e. with no second argument, it outputs it to the row of the script - so naming it would make sense then. This is useful for when you only have one output from your measurement script.
