  3. Error: Parametric simulation failed for first point.
  • Views 18920
Amori85
Amori85 over 12 years ago
Hello All,
I recently installed IC616 with MMSIM 12.1, I am trying to run a parammetric sweep on a simple circuit, but i keep getting the error,
"Parametric simulation failed for first point." , Any idea what could be the cause of this error ?
  • Quek
    Quek over 12 years ago
    Hi Amori85
    Does this also happen if you just use a simple resistor from analogLib? Is there any other info which you can provide?
    Best regards
    Quek
