  3. ADE: How to change default annotation setup?
  • Views 25124
jorgeluislagos
jorgeluislagos over 12 years ago
Hi all! I am wondering, where I can define the DEFAULT annotation setup for components in my schematics (in IC616)?
For instance, for displaying the operating point parameters after a DC analysis I always have to change the annotation settings for my active devices through the View->Annotations-Setup options. It is time consuming having to do the same for each new schematic, so I would like to change the default annotation options for these devices so that they remain like these:
 Parameter:cdsParam(1): DC Operating Point - id
 Parameter:cdsParam(2): DC Operating Point - gm
 Parameter:cdsParam(3): DC Operating Point - vds
 Parameter:cdsParam(4): DC Operating Point - vdsat
 Parameter:cdsParam(5): DC Operating Point - region
Thanks in advance for any help on how to achieve this.
Cheers,
Jorge
    Jorge,
    Please contact customer support for this issue.
  • jorgeluislagos
    Hi Andrew! Thanks for your suggestion, I have channeled my doubt through customer support (case 45570335).
    Jorge.
  • jorgeluislagos
    OK, problem solved! It was just a matter of editing these fields in the component's CDF settings. Thanks for the support!
    Cheers,
    Jorge.
  • Chrisss
    Chrisss over 11 years ago
    Hi, Could you devlop the process to set bu default these annotating dc operation point ?Wich cdf i've to change ?this of mos ?thanks in advance for your help
  • jorgeluislagos
    jorgeluislagos over 11 years ago
    Hi Chris! Indeed, you need to edit the transistor's CDF. The procedure is more or less as follows:
    Go to CIW->Tools->CDF-Edit, then choose correct the library and cell for your device, and "Base" in "CDF Layer". Then go to the tab "Interpreted layers, subtab "Parameters(cdsParam)" and select "Use cdsParam to display: Operating Point Results" and in the right list you can then choose the parameters you with to be display. After playing a while you should be able to make it work.
    Note however that in practice these are read-only cells (from the design kit!), so you might need to make a copy in order to make this work. And there are potential problems that might arise from the fact of working not with the original design kit cells but with local copies!.
    Cheers,
    Jorge.
  • Chrisss
    Thanks for this quick answer. Currently, I did all that you explained but in "user", not in "Base", but no modifications for the display. May be a load had to be done. but I don't know. I've not the rigth to use the "base" option, and working in team, doing that could a source of issue.
