  3. Driving an internal node several heirarchical layers down...
  • Subscribers 132
  • Views 17406
deklein
deklein over 12 years ago
All,
First, an apology. I am new to ADE XL and spectre, coming from hspice and MICA, so if I am asking a really obvious question, please pardon my ignorance. However, in my defence, this is stumping the local ADE XL expert. I have tried various searches of the forums and google without luck. So here goes:
Suppose I have a schematic with an instance of a cell (A) in it. In this instance, there is another instance of cell (B). Now, futher suppose that to test the recovery of a circuit from a particular un-toward upset, I need to reach through the heirarchy and manipulate the voltage on a net in B that I'll call z. I do not have z as a pin on either B or A, it is simply a labeled wire in B. How do I do this?
I've tried doing netsets, net expressions, declaring as global nets, etc. but either I am going it wrong, or it isn't working. And, while bringing this net out to a pin and then up through the heirarchy is possible, it would be a very ugly solution and probably cause trouble when this particular block is wrapped up for P&R. That is, the example I give here is very simple. The actual test case not so much.
I ask because were I running hspice from the command line, I would have a command in the control deck that looked something like this and be done:
gbreakB    xA.xB.z vss vcr pwl(1) verr gnd 0,1e12 1,1e5 2,1 3,1e-5
That is, as I sweep verr from 0v -> 3v, I effectively short z to vss, causing the upset condition in B.
Dave
    Hi Dave,
    You can do this in spectre too. Simply do:
    vbreak (I1.I2.z vss) vsource type=pulse ...
    in spectre syntax. If you are doing this from a schematic (which is presumably the case) you can use the deepprobe component that I created a few years ago as described in this solution. Since there's no support in the schematic editor for doing an out-of-cellView reference, this component allows you to place a component on your schematic where the parameter is the hierarchical node name; it instantiates an iprobe (a zero-volt source) between that hierarchical node and the pin of the instance - so you can then connect whatever you like down through the hierarchy. Obviously this is for testbench use only - more details in the solution.
