  3. "incompatible with data - nil" problem
  • Subscribers 133
  • Views 4669
archive over 18 years ago
Hi, there:
   When I am running Spectre, I got "*Error* fprintf/sprintf: format spec. incompatible with data - nil"
   How can i get rid of it?
Originally posted in cdnusers.org by julian2007
    Unfortunately it could be virtually anything.
    It essentially indicates an untrapped error condition - what's happening is that somewhere in the code it's doing something like:
    printf("blah %s blah\n" myVar)
    and myVar is nil rather than a string as expected. Since fprintf/printf/sprintf is used all over the place, it could happen any time a call to any of these functions happens with an argument that doesn't match the expected type - probably because something unexpected went wrong. This could be in some custom code or in the Cadence code - it could be anywhere.
    To narrow it down a bit, perhaps you could enter in the CIW:
    _stacktrace=20
    tracelevel=20
    tracelength=20
    and then reproduce the problem - and post the lines around problem from your CDS.log file - including what you were doing at the time, and all the stacktrace, etc...
    Probably best to deal with this through customer support really, but I can try to help you here too.
    Originally posted in cdnusers.org by adbeckett
