  3. techDisplays: Failed to set layer-purpose
  • Views 16578
Fabb
Fabb over 12 years ago
While generated a new techFile, i got the following WARNING
INFO (TECH-180024): Created techfile library "xxx"
INFO (TECH-180006): Compiling class 'controls'....
INFO (TECH-180006): Compiling class 'layerDefinitions'....
*WARNING* (TECH-280076): techDisplays: Failed to set layer-purpose pair display attributes because the LPP is not defined in local database.
          The LPP display attributes can only be set in the database where the LPP is defined - (MTJ drawing MTJ_drawing t t t t t).
*WARNING* (TECH-280085): *ERROR* Failed to define layer display for (MTJ drawing MTJ_drawing t t t t t).
INFO (TECH-180006): Compiling class 'layerRules'.
the related techFile code is
; LAYER DEFINITION
layerDefinitions(
techLayers(
;( LayerName                 Layer#     Abbreviation )
;User-Defined Layers:
( MTJ                   400        MTJ          )
);techLayers
techDisplays(
;( LayerName    Purpose      Packet          Vis Sel Con2ChgLy DrgEnbl Valid )
  ( MTJ          drawing      MTJ_drawing      t t t t t )
);techDisplays
) ;layerDefinitions
What is wrong ?
fabrice
    Fabrice,
    You need to define  the layer-purpose-pair in the techLayerPurposePriorities section in order to be able to define the display attributes in techDisplays()
  • Fabb
    Andrew,
    Indeed with techLayerPurposePriorities, it works properly. As my techFile contains only one layer, I though the 'priorities' information was not necessary.
     Fabrice
