  3. Calibre fails to export schematic netlist
  • Views 30541
mhawary85
mhawary85 over 12 years ago
Hi
When I am trying to do Calibre LVS, it gives me error as "Schematic export failed or was cancelled. Please consult the transcript in the viewer window". Unfortunately, The transcript window is empty!
In the CIW window it explains more about the error which is "ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'cdl schematic', for the instance 'T0' in cell 'NMOS_pex'. Either add one of these views to the library 'cmos10lpe', cell 'nfet' or modify the view list to contain an existing view. "
 My schematic is just an NMOS transistor with pins connected on its terminals.
Please note that am using IC6.1.6
Can anyone help me on that issue?
Regards
Mohammad
  • Quek
    Quek over 12 years ago
    Hi Mohammad
    I think you need to "auCdl" as one of the views for exporting the CDL netlist. Would you please look for such a field in the Calibre LVS form and add in "auCdl"?
    Best regards
    Quek
    Maybe you just need to set the netlisting mode first before starting Virtuoso?
    setenv CDS_Netlisting_Mode Analog
    in csh, or:
    export  CDS_Netlisting_Mode=Analog
    in bash/ksh.
    This should tell it to use the auCdl netlister rather than cdl netlister and also pick the appropriate switch and stop lists by default.
  • mhawary85
    Quek and Andrew,
    Thanks for your Replies! Setting the CDS_Netlisting_Mode environment solved the problem.
     Indeed Appreciated!
    Regards
    Mohammad
  • Amit yadav
    Amit yadav over 7 years ago in reply to Andrew Beckett
    Hi
    when i am doing calibre lvs.
    i was facing the same issue as mentioned by Mohammad.
    So after changing "setenv CDS_Netlisting_Mode Analog"
    i am facing ERROR (OSSHNL-514).
    Can You help me regarding this issue?
    Amit
    Andrew Beckett over 7 years ago in reply to Amit yadav
    Hi Amit,
    Please read Guidelines for the Custom IC Design Forum. There you will see that you should post a fresh topic thread for your question rather than posting on the end of a 5 year old thread. Please also provide the complete error message (not just the code) and the IC version you're using (as given by Help->About in the CIW).
