  3. HiSim HV Models do not simulate properly in xfab xdh10 ...
  • Views 14817
HiSim HV Models do not simulate properly in xfab xdh10 pdk
analog2002
analog2002 over 12 years ago
 I am using a pdk from xfab called xdh10.
It includes several high voltage device, I am using device named nd54bs. It uses HiSim HV Model. When I try to simulate it in spectre, the simulation results does not predict the Ron of a single transistor properly
Is there a setting that needs to be set to make it run properly ? Is my spectre cadence version correct ?
The foundry said that they don't see this problem when they ran my test case.  The foundry's environment is given below:-
Cadence: IC6.1.5-64b.500.16
XDH10 pdk: v4_0_1 (under XENV: v1_2_2)
Spectre: 12.1.0.295.isr1 64bit
Models: v4.0.1
 My environment is given below:
The cadence version is : 6.1.5-64b 01/10/2011
spectre version is : 12.1.1.246.isr19 64bit
I am attaching an output.log file for further review.
please comment thanks
Product: Virtuoso Analog Design Environment
Product Feature: ADE-L
My output.log file is attached
thnks
analog2002
    I can't see a good reason why this should work for the foundry but not you, so please contact customer support at http://support.cadence.com so we can look at it with you.
