  3. Generate netlist with subckt statement for top level
  • Replies 12
  • Subscribers 136
  • Views 23072
Octavian
Octavian over 12 years ago
I'm generating a netlist from CIW using:
simulator('spectre)
design("libName" "cellName" "viewName")
createNetlist()
This works fine but I would like to enclose the top level cell in .subckt/ends statements, similar to other cells in the hierarchy. Is that possible using the skill/ocean interface?
--Tavi
    Hi Matthew,
    I'm assuming that the version you mention is ICADV12.1.500.11 (as returned by "virtuoso -W")? If so, then it should be there, because it first appeared in ISR5 (ICADV12.1.500.5) and IC616 ISR3 (IC6.1.6.500.3).
    You will also need to be using MMSIM12.1.1 or later, otherwise it won't show up. Which spectre subversion are you using?
  • Matt Lanahan
    Matt Lanahan over 11 years ago
    You are correct, Virtuoso version is ICADV12.1-64b.500.11.  I am also pointed to MMSIM141_303, and spectre -version returns '14.1.0 64bit'.
    After reading your response I took another look at my script and found the issue.  I copied your envOptions code verbatim, but I had put it at the top of my script where I was already using envSetVal for some other settings.  That did not work.  Just now I moved the envOptions section down inside my gen_netlist procedure, just before I call createNetlist, and now it works.
    Thanks!
