  3. Generate netlist with subckt statement for top level
  • Replies 12
  • Subscribers 136
  • Views 23071
Octavian
Octavian over 12 years ago
I'm generating a netlist from CIW using:
simulator('spectre)
design("libName" "cellName" "viewName")
createNetlist()
This works fine but I would like to enclose the top level cell in .subckt/ends statements, similar to other cells in the hierarchy. Is that possible using the skill/ocean interface?
--Tavi
    Tavi,
    envOption(
            'setTopLevelAsSubckt  t
    Is now available from IC616 ISR3 onwards.
  • Octavian
    Thanks for the prompt reply.
    Is there a similar solution for IC514?
    --Tavi
    Hi Tavi,
    How about the code below. Note that if you want to switch it back in the same session, you'd have to do:
    asiSetNetlistFormatterClass(asiGetTool('spectre) 'spectreFormatter)
    Look at the comments at the top to see the function to initialize the alternative formatter which includes the header for the subckt. The IC616 solution that I mentioned below also incorporates the changes needed (with a recent enough MMSIM version) so that the netlist can still be simulated, using a new switch for spectre to tell it the top subckt to simulate, which the solution below doesn't implement. But if you only want it to produce a netlist, this solution should be sufficient.
    /* abSpectreTopSubckt.ils
    Author     A.D.Beckett
    Language   SKILL
    Date       May 16, 2006
    Modified
    By
    Defines a new formatter, which adds subckt definition around
    top level circuit.
    Does this by extending the spectreFormatter. Note we could directly
    define methods for the spectreFormatter, since it doesn't define
    them itself, but then there is the risk that a future release
    might define methods for spectreFormatter - so better to extend
    rather than make that assumption.
    To install, call (abRegisterSpectreTopCVFormatter)
    SCCS Info: @(#) abSpectreTopSubckt.ils 05/16/06.18:06:00 1.1
    ; Need to have these contexts loaded - in the right order - so
    ; that the spectreFormatter class can be extended
    (foreach context '("oasis" "asimenv" "analog" "spectrei" "spectreinl")
      (unless (isContextLoaded context)
              (loadContext
               (prependInstallPath (strcat "etc/context/" context ".cxt")))
              (callInitProc context)
    ; Define the class for the formatter.
    (defclass abSpectreTopCVFormatter (spectreFormatter)
    *              (abRegisterSpectreTopCVFormatter)               *
    *              Register the formatter with Artist              *
    (defun abRegisterSpectreTopCVFormatter ()
      (let (tool)
           (setq tool (asiGetTool 'spectre))
           (asiSetNetlistFormatterClass tool 'abSpectreTopCVFormatter)
    * (nlPrintTopCellHeader ((formatter abSpectreTopCVFormatter) cellView) *
    *    Method for top level header - call the standard subckt header     *
    (defmethod nlPrintTopCellHeader ((formatter abSpectreTopCVFormatter) cellView)
      (nlPrintSubcktHeader formatter cellView)
      ; don't want comments twice, so don't call the standard formatter?
      ; (when (nextMethodp) (callNextMethod))
    * (nlPrintTopCellFooter ((formatter abSpectreTopCVFormatter) cellView) *
    *    Method for top level footer - call the standard subckt footer     *
    (defmethod nlPrintTopCellFooter ((formatter abSpectreTopCVFormatter) cellView)
      (nlPrintSubcktFooter formatter cellView)
  • Octavian
     It works!
     Thank you.
  • NcfC
    NcfC over 12 years ago
    Hi, Andrew. I placed your code, followed by Tavi's code, inside a procedure, but I got some problems.
    If I call the procedure from within CIW, I don't get any errors and the netlist is generated as it should be.
    But if I placed it as a sub menu item,
     procedure( AddItemSubHier( _args )
    let( ( fileMenu slider MenuItemSubCktNetlist )
    fileMenu = car( setof( menu hiGetBannerMenus( hiGetCurrentWindow() ) rexMatchp("^schFileMenu" menu ) ) )
    if( fileMenu
    slider = eval( car( setof( item eval( fileMenu )->? rexMatchp( "^schHierSlider" item ) ) ) )
    MenuItemSubCktNetlist = hiCreateMenuItem( ?name 'menu1 ?itemText "Netlist - Subcircuito" ?callback "Netlist_TopLevel_SubCkt()" )
    when( !slider->menu1 hiInsertMenuItem( slider MenuItemSubCktNetlist length( slider->? ) ) )
    ) ;let
    ) ;procedure
    deRegUserTriggers( "schematic" nil nil 'AddItemSubHier )
    and load it in the cdsinit.il file, I get the following error:
    *Error* _iliGetSlotSpecs: not a class object or class name - spectreFormatter
    What have I done wrong?
    Thanks in advance.
    Best regards,
    I think you'll have to show what Netlist_TopLevel_SubCkt looks like. I'm not sure what you mean by placing my code followed by Tavi's in a procedure. My code relies on pre-loading some context files before defining some classes - so I'm guessing something got screwed up somewhere as it doesn't know what spectreFormatter is. So please share the code so that I can check it - you've only shown the menu definition, which is not the interesting part...
  • NcfC
    Hi, Andrew.
    No problem. Here it is:
    let( ( fileMenu slider MenuItemNetlist )
    if( fileMenu
    MenuItemNetlist = hiCreateMenuItem( ?name 'menu1 ?itemText "Netlist - Subckt" ?callback "Netlist_TopLevel_SubCkt()" )
    when( !slider->menu1 hiInsertMenuItem( slider MenuItemNetlist length( slider->? ) ) )
    ) ;let
    ) ;procedure
    procedure( Netlist_TopLevel_SubCkt()
    let( ( sch design )
    (loadContext
    (let (tool)
    simulator( 'spectre )
    sch = geGetEditCellView()
    design( sch~>libName sch~>cellName sch~>viewName )
    createNetlist()
    ) ; let
    ) ; procedure
    Best regards,
    Don't nest all the code inside Netlist_TopLevel_SubCkt(). The procedures won't be local (unless you're using SKILL++ and have a .ils suffix), and even then some of it will be evaluated at the wrong time. There's no need to do it that way. Load the code I gave you, and define your function like this:
    let( ( sch )
        abRegisterSpectreTopCVFormatter()
        sch=geGetEditCellView()
        createNetlist()
    (Note, I didn't test the above code).
  • NcfC
    Hi, Andrew.
    Thanks very much. It worked just fine (I just had to add the line for the simulator!).
    Best regards,
  • Matt Lanahan
    Matt Lanahan over 11 years ago
    The setTopLevelAsSubckt option doesn't appear to work in ICADV121_110.  Is that feature only available in IC616?
    I was able to get running using your abSpectreTopSubckt.ils, so thank you for that.
