  3. MMSIM, ADE no Convergence during simulation...
  • Replies 10
  • Views 23016
marten
marten over 12 years ago
Hi all,
we just setup a new installation of MMSIM 12.11, IC6.16 and a 28nm PDK. After installing these tools and configuring PDK with the given scripts we built a simple NAND2 schematic to test our setup. But when it comes to simulation the simulator is not able to reach convergence. What could be the reason for this? We simulated the same Design with out legacy 65nm environment and it worked.So maybe this is a PDK issue ? But how to fix ?
Best regard,
Marten
Here is a part of the logfile written out by spectre:
 ...Warning from spectre during AHDL read-in.
    WARNING (VACOMP-2343): Cannot display/strobe/write information or call $system from a protected analog block.
    WARNING (VACOMP-1050): Encountered warnings in encrypted file "./designkits/DATA/MODELS/SPECTRE/CORNERS/ESD_DIODEGR.va".
Reading file:  ./designkits/DATA/MODELS/SPECTRE/CORNERS/ESD_DIODE.va
        Further occurrences of this warning will be suppressed.
    WARNING (VACOMP-1050): Encountered warnings in encrypted file "./designkits/DATA/MODELS/SPECTRE/CORNERS/ESD_DIODE.va".
Reading file:  ./designkits/DATA/MODELS/SPECTRE/CORNERS/esdlayer.va
Reading file:  ./simulation/nand_tb/spectre/schematic/netlist/setupCornersIncludeFile.scs
Reading file:  :/simulation/nand_tb/spectre/schematic/netlist/importNetlist.scs
Time for NDB Parsing: CPU = 330 ms, elapsed = 10.3906 s.
Time accumulated: CPU = 330 ms, elapsed = 10.3906 s.
Peak resident memory used = 48.1 Mbytes.
Reading link:  ./cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/ahdl/discipline.h
Warning from spectre in `LL_NAND2AX9_P0':`I0', during hierarchy flattening.
    WARNING (SFE-32): "input.scs" 14: Duplicate specification for parameter `ptwell' (using last value specified).
    WARNING (SFE-32): "input.scs" 20: Duplicate specification for parameter `ptwell' (using last value specified).
    WARNING (SFE-32): "input.scs" 26: Duplicate specification for parameter `ptwell' (using last value specified).
    WARNING (SFE-32): "input.scs" 32: Duplicate specification for parameter `ptwell' (using last value specified).
    WARNING (SFE-32): "input.scs" 38: Duplicate specification for parameter `ptwell' (using last value specified).
Time for Elaboration: CPU = 40 ms, elapsed = 41.4619 ms.
Time accumulated: CPU = 370 ms, elapsed = 10.4323 s.
Peak resident memory used = 54.3 Mbytes.
Time for EDB Visiting: CPU = 0 s, elapsed = 1.091 ms.
Time accumulated: CPU = 370 ms, elapsed = 10.4335 s.
Peak resident memory used = 54.6 Mbytes.
Loading ./cadence/mmsim-12.11hf096/tools.lnx86/spectre/lib/64bit/mdl/libSpectreEH_sh.so ...
Notice from spectre during topology check.
    No DC path from node `vdds!' to ground, Gmin installed to provide path.
    No DC path from node `gnds!' to ground, Gmin installed to provide path.
Circuit inventory:
              nodes 7
             iprobe 39
             assert 56
              utsoi 8
            vsource 2
Notice from spectre.
    6 warnings suppressed.
Time for parsing: CPU = 100 ms, elapsed = 104.374 ms.
Time accumulated: CPU = 470 ms, elapsed = 10.538 s.
Peak resident memory used = 66 Mbytes.
Warning from spectre.
    WARNING (SPECTRE-16707): Only tran supports psfxl format, result of other analyses will be in psfbin format.
Notice from spectre during transient analysis `tran'.
    No checklimit analysis defined for asserts. A default checklimit analysis 'SpectreChecklimitAnal' has been created with all asserts enabled.
The following asserts will be enabled for all subsequent analyses until the next checklimit analysis statement is found:
I0.M0.soa_299 : ON
I0.M0.soa_300 : ON
I0.M0.soa_301 : ON
I0.M0.soa_302 : ON
I0.M0.soa_303 : ON
I0.M0.soa_304 : ON
I0.MP0.soa_299 : ON
I0.MP0.soa_300 : ON
I0.MP0.soa_301 : ON
I0.MP0.soa_302 : ON
I0.MP0.soa_303 : ON
I0.MP0.soa_304 : ON
I0.MP3.soa_299 : ON
I0.MP3.soa_300 : ON
I0.MP3.soa_301 : ON
I0.MP3.soa_302 : ON
I0.MP3.soa_303 : ON
I0.MP3.soa_304 : ON
I0.MP1.soa_299 : ON
I0.MP1.soa_300 : ON
I0.MP1.soa_301 : ON
I0.MP1.soa_302 : ON
I0.MP1.soa_303 : ON
I0.MP1.soa_304 : ON
I0.MP2.soa_299 : ON
I0.MP2.soa_300 : ON
I0.MP2.soa_301 : ON
I0.MP2.soa_302 : ON
I0.MP2.soa_303 : ON
I0.MP2.soa_304 : ON
I0.MN2.soa_292 : ON
I0.MN2.soa_293 : ON
I0.MN2.soa_294 : ON
I0.MN2.soa_295 : ON
I0.MN2.soa_296 : ON
I0.MN2.soa_297 : ON
I0.MN1.soa_292 : ON
I0.MN1.soa_293 : ON
I0.MN1.soa_294 : ON
I0.MN1.soa_295 : ON
I0.MN1.soa_296 : ON
I0.MN1.soa_297 : ON
I0.MN0.soa_292 : ON
I0.MN0.soa_293 : ON
I0.MN0.soa_294 : ON
I0.MN0.soa_295 : ON
I0.MN0.soa_296 : ON
I0.MN0.soa_297 : ON
I0.MN0.soa_298 : ON
I0.MN1.soa_298 : ON
I0.MN2.soa_298 : ON
I0.MP2.soa_305 : ON
I0.MP1.soa_305 : ON
I0.MP3.soa_305 : ON
I0.MP0.soa_305 : ON
I0.M0.soa_305 : ON
Transient Analysis `tran': time = (0 s -> 5 ns)
Trying `homotopy = gmin' for initial conditions.
Trying `homotopy = source' for initial conditions.
Trying `homotopy = dptran' for initial conditions...
Trying `homotopy = ptran' for initial conditions..
Trying `homotopy = arclength' for initial conditions.
None of the instantiated devices support arclength homotopy. Skipping.
Error found by spectre during IC analysis, during transient analysis `tran'.
    ERROR (SPECTRE-16080): No DC solution found (no convergence).
The values for those nodes that did not converge on the last Newton iteration are given below.  The manner in which the convergence criteria were not satisfied is also given.
            Failed test: | Value | > RelTol*Ref + AbsTol
 Top 10 Residue too large Convergence failure:
    I(I0:6) = 0 A
        residue too large: | -1.2 V | > 6 mV + 1 uV
    I(I0:2) = 0 A
The following set of suggestions might help you avoid convergence difficulties.  After you have a solution, write it to a nodeset file by using the `write' parameter, and read it back in on subsequent simulations by using the `readns' parameter.
 1. Evaluate and resolve any notice, warning, or error messages.
 2. Perform sanity check on the parameter values by using the parameter range checker (use ``+param param-limits-file'' as a command line argument) and heed any warnings.  Print the minimum and maximum parameter value by using `info' analysis.  Ensure that the bounds given for instance, model, output, temperature-dependent, and operating-point (if possible) parameters are reasonable.
 3. Check the direction of both independent and dependent current sources. Convergence problems might result if current sources are connected such that they force current backward through diodes.
 4.  Enable diagnostic messages by setting option `diagnose=detailed'.
 5. Small floating resistors connected to high impedance nodes can cause convergence difficulties. Avoid very small floating resistors, particularly small parasitic resistors in semiconductors. Instead, use voltage sources or iprobes to measure current.
 6. If you have an estimate of what the solution should be, use nodeset statements or a nodeset file, and set as many nodes as possible.
 7. Use realistic device models. Check all component parameters, particularly nonlinear device model parameters, to ensure that they are reasonable.
 8. If simulating a bipolar analog circuit, ensure that the region parameter on all transistors and diodes is set correctly.
 9. Loosen tolerances, particularly absolute tolerances like `iabstol' (on options statement). If tolerances are set too tight, they might preclude convergence.
10. If the analysis fails at an extreme temperature, but succeeds at room temperature, try adding a DC analysis that sweeps temperature. Start at room temperature, sweep to the extreme temperature, and write the final solution to a nodeset file.
11. Increase the value of gmin (on options statement).
12. Use numeric pivoting in the sparse matrix factorization by setting `pivotdc=yes' (on options statement). Sometimes, it is also necessary to increase the pivot threshold to a value in the range of 0.1 to 0.5 by using `pivrel' (on options statement).
13. Try to simplify the nonlinear component models to avoid regions that might contribute to convergence problems in the model.
14. Divide the circuit into smaller pieces and simulate them individually. However, ensure that the results are close to what they would be if you had simulated the whole circuit.  Use the results to generate nodesets for the whole circuit.
15. If all else fails, replace the DC analysis with a transient analysis and modify all the independent sources to start at zero and ramp to their DC values. Run transient analysis well beyond the time when all the sources have reached their final value (remember that transient analysis is very cheap when none of the signals in the circuit are changing) and write the final point to a nodeset file. To make transient analysis more efficient, set the integration method to backward Euler (`method=euler') and loosen the local truncation error criteria by increasing `lteratio', say to 50. Occasionally, this approach fails or is very slow because the circuit contains an oscillator.  Often, for finding the dc solution, the oscillation can be eliminated for by setting the minimum capacitance from each node to ground (`cmin') to a large value.
Analysis `tran' was terminated prematurely due to an error.
finalTimeOP: writing operating point information to rawfile.
Error found by spectre during DC analysis, during info `finalTimeOP'.
    ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point.
Analysis `finalTimeOP' was terminated prematurely due to an error.
modelParameter: writing model parameter values to rawfile.
element: writing instance parameter values to rawfile.
outputParameter: writing output parameter values to rawfile.
designParamVals: writing netlist parameters to rawfile.
primitives: writing primitives to rawfile.
subckts: writing subcircuits to rawfile.
    Assuming that the standard cell is using vdd! and gnd! as its supplies, then I can't see a good reason for this unless there are problems in the PDK. You should either contact the foundry or customer support so that we can take a look at this with you. It seems odd that such a simple circuit has a convergence problem unless something is very wrong with the setup or models, and we'd need to see the data to understand that.
  • Marc Heise
    Marc Heise over 12 years ago
    What about these:
    Floating bulk nodes? Could be the reason for the convergence problem.
    Marc
    Marc,
    Well spotted. That's aligned with my earlier suggestion that the global nets inside the standard cell might not be the same as what you have on your top level testbench (which are vdd! and gnd! rather than vdds! and gnds!), so they would be floating, which mean your standard cell has no power and ground.
    That's rather likely to cause convergence troubles!
  • marten
    Hey there,
    thanks for your replies!
    I just came by to report how I fixed the issues. First of all you both are right, gnds and vdds were floating...
    After fixing this issue I also had to change the "skipdc" option from "all" to either "rampup" or "autodc" to get convergence.
     Cheers,
    Marten
    Marten,
    That seems very odd for such a simple circuit. I wouldn't expect you to have to do that. It sounds as if something else might be wrong in the connectivity. Perhaps you could contact customer support so that we can take a look at your circuit and the models and check it out more carefully. Or maybe  you could just post the input.scs here so we can take a look and see if anything obvious jumps out.
  • marten
    here is an excerpt from the spectre logfile:
    Loading /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/cmi/lib/64bit/5.0/libinfineon_sh.so ...
    Loading /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/cmi/lib/64bit/5.0/libphilips_o_sh.so ...
    Loading /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/cmi/lib/64bit/5.0/libphilips_sh.so ...
    Loading /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/cmi/lib/64bit/5.0/libsparam_sh.so ...
    Loading /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/cmi/lib/64bit/5.0/libstmodels_sh.so ...
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/input.scs
    Reading file:  /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/configs/spectre.cfg
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/models.scs
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/hiddenOptions.scs
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/corners.scs
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/stat_flags.scs
    Reading file:  /home/gresievers/marten/cds_28/simulation/nand2_tb/spectre/schematic/netlist/soa_flags.scs
    Reading link:  /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/ahdl/constants.h
    Reading file:  /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/ahdl/constants.vams
    Reading link:  /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/ahdl/disciplines.h
    Reading file:  /sct/homes3/cadence/mmsim-12.11hf096/tools.lnx86/spectre/etc/ahdl/disciplines.vams
    Maybe you can see something suspicious there ?
    Cheers,
    Marten
    Hi Marten,
    Not sure why you thought that an excerpt showing me which files were read would show me anything suspicious! That didn't tell me anything useful at all...
    As I said, the input.scs is far more likely to be useful - if it's a single gate, presumably it's not very big...
  • marten
     my fault I misunderstood something there...
    I am not sure if I am allowed to post the physical parameters, so here goes an excerpt of my input.scs:
     // Generated for: spectre
    // Generated on: Mar 27 15:40:13 2014
    // Design library name: myTest
    // Design cell name: nand2_tb
    simulator lang=spectre
    global 0 vdd!
    include "models.scs"
    // Library name: SC_CORE_LL
    // Cell name: NAND2X9
    // View name: cmos_sch
    subckt NAND2X9 A B Z inh_gnd inh_gnds inh_vdd inh_vdds
    ends NAND2X9
    // End of subcircuit definition.
    // Library name: myTest
    // Cell name: nand2_tb
    // View name: schematic
    V2 (net4 0) vsource dc=1.2 type=dc
    V0 (vdd! 0) vsource dc=1.2 type=dc
    I2 (0 net4 OUT 0 0 vdd! vdd!) NAND2X9
    simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
        tnom=25 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
        checklimitdest=psf
    tran tran stop=20n errpreset=conservative start=0 outputstart=0 step=20p \
        maxstep=200p ic=all skipdc=no cmin=0 write="spectre.ic" \
        writefinal="spectre.fc" method=gear2only relref=alllocal lteratio=10 \
        annotate=status
    subckts info what=subckts  where=rawfile
    saveOptions options save=allpub subcktprobelvl=2
    Unfortuntely that's also not very useful since you've removed the actual circuit. One of the things I was going to check was the size of the transistors (w and l). A common mistake is to specify the transistor dimension in microns, but the models are expecting them in metres - so you end up with the transistors a million times bigger than they should be. I just wanted to check it was nothing obvious like that.
    If you can't share this in a public forum, I would suggest you contact customer support as you really should not have such convergence difficulties with such a trivially small circuit. Convergence is generally pretty good in spectre (although it is dependent upon the models), but it seems very odd that such a simple circuit would have issues unless there is something wrong with the design.That's why support can help - we can take a look and figure that out.
  • marten
     Okay with the help of our PDK vendor, we could fix the problem. It came out that MMSIM v11.12.096 had known Convergence issues, so we installed a new Version of MMSIM (v. 11.12.330). Now everything works perfectly!
    Cheers,
    Marten
