  3. Selecting a lot of objects in Virtuoso Layout Editor, Cadence...
  • Views 8423
Selecting a lot of objects in Virtuoso Layout Editor, Cadence 5141.
TiNat
TiNat over 12 years ago
Hello. I use Cadence 5141. In Virtuoso Layout Editor I want replace library of elements in layout drsign. Use command  Search... and  then option replace.  In case number of elements, for example,  70000, tool select them  ~10 seconds,  In case number of elements 120000, then tool need more time, but  negligible: ~30 seconds. But   In case number of elements 180000 (for example), then cadence doesn't response. I wait one hour, but elements didn't select, and memory in computer does't busy. Somebody can give a hint, is it a bug of Cadence, or tool have a limit of selected elements. Can I solve this problem?
Thanks for your answers.
Best regards.
  • Quek
    Quek over 12 years ago
    Hi TiNat
    It is a little hard to tell if this is a bug without a testcase. I suspect that it might be a limitation of IC5141. It is actually already a very out-dated tool. It would be good if you can switch to IC616. You can also try using the latest version of IC5141 (5141-500-6-151) to see if it helps.
    Best regards
    Quek
    Hi TiNat,
    I just tried creating a million rectangles in IC5141 (latest hotfix) and then selecting them. The selection took maybe 2-3 seconds.
    If I then tried doing length(geGetSelSet()) it was very slow, as it was spending a lot of time garbage collecting. This is because it has to build SKILL list and dbobjects for each item, and that exceeds the pool size for each object, which results in it performing a fair number of garbage collections prior to each memory allocation.
    I improved that by using:
    needNCells('list 1500000)
    needNCells('dbobject 1500000)
    And then the length() was almost instantaneous. Maybe there's something in your environment which is looking at the SKILL objects, so doing this needNCells might help? Although I'm not convinced...
    Note that the numbers I chose above (1.5 million) maybe a bit high for the size of data you have, but it shouldn't be too expensive in terms of memory usage.
  • TiNat
    Thank you, Andrew. I understand, that for large projects (where a lot of objects ) it is necessary to use only SKILL, not GUI. I have solved my problem using next SKILL:
    ih = car(setof( instHead cv~>instHeaders instHead~>libName == "projlib" && instHead~>cellName == "pmos"))
    dbSetInstHeaderMasterName(ih "new_projlib" ih~>cellName ih~>viewName)
    instead of commands Search... and then replace.
