  3. Remedy required for Error OSSGLD-84
  • Views 15096
firish
firish over 12 years ago
could someone suggest the remedy for error OSSGLD-84, the net expression '[@sub:%:sub!]' on instance 'Q3' in the cellview could not be evaluated because the signal sub! was not found in the same cellview.Check the net expression and signal location.
    It's telling you that you don't have a signal called "sub!" - hard to be sure without seeing the data, but did you try doing a check-and-save on the schematic containing Q3 (I'm not sure how this could have happened). Alternatively, it's something wrong with the symbol itself.
    Probably best if you can contact customer support so that we can see the error message in the context of the data.
    Kind Regards,
  • skillUser
    skillUser over 12 years ago
    you might find Solution Article 11517752 helps with your issue?
    Lawrence.
