  3. ADE-XL closed with distributed jobs running
  • Views 15409
The Setlaz
The Setlaz over 12 years ago
I had an ADE-XL session that I had to kill while it had distributed job running on LSF farm.
The distributed job didn't die and simulation completed successfully and I can access the PSF via the Results Browser and get results or post-process it with OCEAN without any issue.
However, in the ADE-XL, all the outputs in the "Results" tab are still marked as "Running". I can evaluate manually (right clic -> Plot) some of them (seems only the ones that returns waveforms) but I can't evaluate those that returns numerical values.
Is there a way to "Refresh" the ADE-XL state of simulation make it recognizing all the runs as finished and evaluate the output  ?
Damien
    Damien,
    This can be done but needs some internal functions which I don't want to share on this forum. I have some code to do this, and I can share it - so please contact customer support and ask the team to put me in touch (of course, if you know my email address, you can put me on cc when you log the case).
  • The Setlaz
    No problemn. I created a case and CC'ed you on it -  CCR #45577268
    Damien
